MAJOR ELECTRICAL PROBLEM
Old Oct 2, 2007 | 02:57 PM
5_Lug_B's Avatar
* B A N N E D *
Default MAJOR ELECTRICAL PROBLEM
I was doing some work to my car today and i had the radio on and the car on option when i realized the radio would turn on and off by itself. So I played around with it then I heard a weird noside coming from my fuse box under the dash and there was a little electrical explosion coming from the 3rd bottom row. I turned the car off and checked all the fuses and every single one of them was fine. Now I thought that was weird so I put everything back together and went to crank up the car and nothing, the main relay will click but the fuel pump wont prime nor will the starter engage. When I go to turn the headlights on they are very dim then on the third click they completely die out and wont come on. Anybody have any input or am I going to have to rip out every single part?
Old Oct 2, 2007 | 05:34 PM
Tomdata's Avatar
Default Re: MAJOR ELECTRICAL PROBLEM (5_Lug_B)
before you get too extreme, make sure the battery cable/connections are good and not corroded and that the smaller wires going to the underhood fuse box are tightly connected.
Old Oct 2, 2007 | 07:10 PM
Aquafina's Avatar
Default Re: MAJOR ELECTRICAL PROBLEM (Tomdata)
After you do that, bust out the multimeter.
El3ments
Jun 2, 2008 11:55 AM
altoid
Nov 25, 2007 03:10 PM
5_Lug_B
Oct 2, 2007 03:14 PM
HT Chaplain
Jan 29, 2005 05:13 PM
TurboFryBox
Apr 2, 2003 01:42 AM
