Cleaning Injectors
Old Oct 4, 2007 | 10:31 AM
Mr.Death's Avatar
Default Cleaning Injectors
I think one of my injectors is dirty causing LOTS of carbon build up in cylinder 4(nearest dizzy). All other cylinders looked good when I checked the plugs except cylinder 4. I did some research and from what I understand the pros use a ultra sonic bath to free up debris and flush out the injector. At work I have such a machine but I need to know what type of solvent I should use to "bath" the injectors in?
Thanks
Old Oct 5, 2007 | 04:24 PM
LsCivic18's Avatar
You Can Use Brake Or Throttle Bodt Cleaner, That What I Used When I Cleaned Mine
Old Oct 6, 2007 | 10:43 AM
mmuller's Avatar
Mad Scientist
Default Re: Cleaning Injectors (Mr.Death)
unless you rig something to pulse the injectors while on the ultrasonic cleaner, its going to do you no good.
Old Oct 7, 2007 | 06:08 PM
Muckman's Avatar
Moderator in Chief
Default Re: Cleaning Injectors (mmuller)
Use one of those big 12v lattern batteries (not a car battery) and touch the leads with some wire. it will pulse.
harmonator84
Jan 17, 2007 10:41 AM
delslowh23
Dec 31, 2003 02:19 PM
poid
Apr 12, 2003 08:53 PM
Heavy Pee
Jul 17, 2002 09:02 PM
