rusted block?
Old Sep 28, 2007 | 09:11 AM
usdm_dc2's Avatar
Default rusted block?
i got an 01 gsr block and i left it outside over night. i guess the dew or something made the walls rusted. do i have to rehone the block? lats of people are teling me to just pour some deisel fuel in the chambers and it will get the rust off and the rings should be good..... is this true? feed back.
Old Sep 28, 2007 | 01:25 PM
Kegan's Avatar
When I swapped a Z6 into a rex, the cylinder walls did the same thing. We just put her in and started he up, ran just fine. Wouldn't necessarily recommend it, but didn't hurt my motor.
Old Sep 28, 2007 | 01:44 PM
usdm_dc2's Avatar
Default Re: (Kegan)
kinda scared to just throw a head on it burn it off. dont want to have to go oversized
Old Sep 28, 2007 | 01:53 PM
King V's Avatar
Default Re: (usdm_dc2)
I've heard from some domestic old iron hot rodders that they actually let the cylinder walls rust a little(slight patina) to supposedly help the rings seat faster. Something to do with the abrasive type action the rust has. Personally i wouldn't do that, but hey, I don't hot rod domestics. I've heard Coca Cola eats rust pretty well too....
Old Sep 28, 2007 | 05:59 PM
91DA9's Avatar
Default Re: (King V)
Since it is just a light surface rust, you can probably get away with wetting a towel with some kind of lubricant, such as diesel fuel, and wiping the surface rust away. Also, if the rust ate away the cross-hatching in the bores, it might be a good idea to restore that with very fine sandpaper.
I would think that even small specks of rust would be bad for the oil control rings, but I am by no means a professional engine builder.
Old Sep 29, 2007 | 10:58 PM
ToeJam's Avatar
Default Re: (91DA9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91DA9 &raquo;</TD></TR><TR><TD CLASS="quote">Since it is just a light surface rust, you can probably get away with wetting a towel with some kind of lubricant, such as diesel fuel, and wiping the surface rust away. Also, if the rust ate away the cross-hatching in the bores, it might be a good idea to restore that with very fine sandpaper.
I would think that even small specks of rust would be bad for the oil control rings, but I am by no means a professional engine builder. </TD></TR></TABLE>
SANDPAPER?! wow, what ever you do do not use sand paper on it. It sounds like you do not have a rust problem at all. even if you do its very VERY small, considering that it happened over night. take a paper towel and some wd40, it should do the trick.
Old Sep 30, 2007 | 06:39 AM
usdm_dc2's Avatar
Default Re: (ToeJam)
reply well no its on there pretty good. i tried wd 40 and a towel it looks like it needs to soak or somethin
Luward
Dec 22, 2013 06:06 PM
boostedteg4dr
Apr 6, 2009 03:30 PM
9 CRX si 1
May 3, 2006 12:28 AM
92BlackSi
Aug 31, 2003 08:41 AM
Apex i ITR
Aug 12, 2002 01:34 PM
