starting issue/ possible spark
Old Sep 30, 2007 | 07:21 AM
A2gt35r's Avatar
Default starting issue/ possible spark
Car was starting fine & I just pulled the injector wires & plugs to do a comp test & did the test & haven't tried to start in about 4 days. I tried to start & just keeps cranking, it has fuel to the injectors & just would like to know what voltage tester to get to check injectors & where to check for spark, meaning plug wires, cap etc?
Thanks.
Old Sep 30, 2007 | 11:34 AM
ek_chris's Avatar
easiest way is to pull a plug and put it in the wire, ground it and get a friend to crank it.
Chances are your firing order is wrong or something silly. WHat I would do is pull all four plugs and check to see if they have fuel on them, that way you know its an ignition issue (well most likely an ign. issue)
Old Sep 30, 2007 | 06:26 PM
A2gt35r's Avatar
Got t frind to help & it was the ign. & will replace the distributor tomorrow.
Thanks.
gerbsgsr
15
Dec 28, 2015 08:46 PM
j4yzn
Aug 24, 2009 12:45 PM
Civic Hybrid
10
Aug 17, 2008 09:35 AM
si_motor_spt
Sep 2, 2007 06:57 PM
GoldCoin
Aug 21, 2006 06:29 PM
