quick question OBD1 and OBD2
Old Sep 26, 2007 | 10:38 AM
topherchris's Avatar
Default quick question OBD1 and OBD2
i dont really understand the difference between OBD1 and OBD2, i was told its just one wire, so is it possible to buy an OBD2 motor and hook up an OBD1 harness and vise versa and ECU? i guess what im trying to ask is how do i know what harness/motor/ecu years i need and what can i swap?
Old Sep 26, 2007 | 06:43 PM
red96civicex's Avatar
well first you should tell us what kind of car YOU have, then we can go from there, as far as obd1 and 2, obd1 only uses 1 o2 sensor, and obd2 uses 2, a primary and secondary. also, no obd1 engine has a knock sensor, any VTEC engine made after 96 has one. any vehicle made after 1996 is obd2. you can put a obd2 motor in an obd1 engine 2 ways, you can change the dizzy, injectors, and alternator to obd1 or you can just get the plug for each and re-wire them to the obd1 harness, know what i mean? and vice versa for a obd1 motor in a obd2 car. and for obd2 you can get a conversion harness to use a obd1 ecu for the engine
Old Sep 26, 2007 | 07:30 PM
Blown90hatcH's Avatar
Default Re: (red96civicex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by red96civicex &raquo;</TD></TR><TR><TD CLASS="quote">also, no obd1 engine has a knock sensor, any VTEC engine made after 96 has one. </TD></TR></TABLE>
Um...OBD1 P72, OBD1 P30, OBD1 P13....all utilized and had inputs for a knock sensor.
soon2bdropped
Aug 30, 2007 10:32 AM
PressurizedSi
Nov 27, 2006 07:47 AM
boost fed ls
Aug 6, 2004 05:06 AM
92civic_si
16
May 6, 2004 02:50 PM
D16Z6racing
12
Jul 26, 2002 02:15 PM
