h2b block grinding
Old Oct 5, 2007 | 09:13 AM
PissedoffHONDA's Avatar
Default h2b block grinding
what kind of grinder you guys use to grind the back of the block? will a regular air die grinder work? do i need an ANGLED grinder? Please give me some ideas.
Old Oct 5, 2007 | 10:23 AM
SlowReaction's Avatar
Default Re: h2b block grinding (PissedoffHONDA)
I dont think it matter what kind of grinder you use as long as it works. Just make sure you use the right kind of disc.
Old Oct 5, 2007 | 12:06 PM
so i can use one of those 1/4" die grinders ?
Old Oct 5, 2007 | 08:55 PM
Lubo_25's Avatar
angle grinder with flap wheel eats at it nicely
Old Oct 6, 2007 | 03:12 AM
lol cool ill pick up a 4 1/2" angle grinder.
Old Oct 7, 2007 | 07:35 PM
got the angle grinder. what edge of the disk do i grind? what i mean is hold the grinder sideways or up in down or does it matter. sorry for the lame question just dont want to mess the block up.
Old Oct 8, 2007 | 07:23 AM
skunked's Avatar
Make sure you wear some safety glasses and put a garbage bag around the motor to keep the metal away.
Old Oct 8, 2007 | 08:10 AM
gibsanez's Avatar
Default Re: h2b block grinding (skunked)
Do it in a well ventilated area, aluminum dust will give you a nasty headache.
Old Oct 8, 2007 | 11:56 AM
wow cool. most other people are doing it with the edge of the disk. im kinda of nervous.
Old Oct 8, 2007 | 12:34 PM
gibsanez's Avatar
Buy a flap-wheel if you aren't confident, they only go one way
Old Oct 8, 2007 | 12:51 PM
i guess if i go slow it will be ok. and dont put pressure.
Old Oct 9, 2007 | 09:50 AM
Bense's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PissedoffHONDA &raquo;</TD></TR><TR><TD CLASS="quote">wow cool. most other people are doing it with the edge of the disk. im kinda of nervous.</TD></TR></TABLE>
if you've never used a grinder, just go get a random piece of metal and just grind stupid **** into it. you'll get so much grinding confidence
Old Oct 9, 2007 | 01:45 PM
hpi247's Avatar
Default Re: h2b block grinding (Bense)
i wish i bought a grinder. ended up using a dremel, and A LOT of demel wheels.
Old Oct 9, 2007 | 01:46 PM
skunked's Avatar
Default Re: h2b block grinding (hpi247)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hpi247 &raquo;</TD></TR><TR><TD CLASS="quote">i wish i bought a grinder. ended up using a dremel, and A LOT of demel wheels.</TD></TR></TABLE>
damn, that must have took hours
Old Oct 9, 2007 | 01:49 PM
hpi247's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunked &raquo;</TD></TR><TR><TD CLASS="quote">
damn, that must have took hours </TD></TR></TABLE>
it was a pain. especially since i didnt grind enough off and had to continue grinding while the engine was mounted. oh well, it was worth it. H2B is the sh*t
Old Oct 9, 2007 | 01:51 PM
skunked's Avatar
it was a pain. especially since i didnt grind enough off and had to continue grinding while the engine was mounted. oh well, it was worth it. H2B is the sh*t </TD></TR></TABLE>
It's a good idea to fit the midshaft and axle on the block while the motor is out
I had to grind a little as well, not fun on your back under the car
Old May 23, 2008 | 08:21 AM
n1_RT's Avatar
Hey how much is there to grind? i have the QSD kit but i can only get a DA intermediate shaft and for some reason my DC intermediate shaft will not fit.
Eyger
Paint and Body
Mar 9, 2009 01:08 PM
b16a4
25
Jul 16, 2007 08:15 AM
D-booster
Jun 24, 2004 09:13 AM
SOUNDEFFECTS
Nov 26, 2002 07:23 AM
T4sol
May 21, 2002 08:07 AM
