spark advance - is it really hard on a bottom end?
Old Nov 10, 2001 | 02:56 PM
Greyout's Avatar
Default spark advance - is it really hard on a bottom end?
Factory spark on my lude is 15 degrees before TDC, with a error range of +/- 2 degrees.
I went two degrees outside of that (just cranking the distributor back) so I'm at 19 degrees, or +4 from stock.
Is this bad? Am I actually making more power?
once again, this is NOT cam gear advancing, this is just spark advance. This is on a JDM h22 with 45,000 miles.
Old Nov 10, 2001 | 07:56 PM
redsin95's Avatar
New User
Default Re: spark advance - is it really hard on a bottom end? (JDM LUDE)
it should not be to bad. i would retard it at least one or two degrees and only advance it about 2 degrees, but you shoudl be fine. the only way it will hurt you is if yoru getting detination, if not don't worry about it.
dk=gsr
Oct 14, 2010 04:20 PM
shooter93
May 10, 2009 08:23 PM
SupraRXZ
Feb 24, 2006 04:31 PM
Layziebtnh055
Aug 24, 2004 08:32 AM
ludetech
May 20, 2004 10:33 AM
