piston to wall clearance with forged pistons
Old Nov 7, 2001 | 09:09 AM
boosted3g's Avatar
Default piston to wall clearance with forged pistons
I am curious as to what the optimal piston to wall clearance should be with forged pistons due to the expansion when they heat up. I am in the process of putting my engine together and want to do everything right. I will be using JE pistons.
Old Nov 7, 2001 | 09:24 AM
Max GSR's Avatar
Default Re: piston to wall clearance with forged pistons (boosted3g)
You can check out Endyn's site for some typical clearances with forged pistons:
http://www.theoldone.com/articles/en...ata_sheet.html
Old Nov 7, 2001 | 10:30 AM
boosted3g's Avatar
Default Re: piston to wall clearance with forged pistons (Max GSR)
that was some great info but are you sure that is for forged pistons. They seem a little on the tight side.
Old Nov 7, 2001 | 01:03 PM
Blown90hatcH's Avatar
How much boost? talked to a tech at JE. I told him my piston spec, how much boost and he said 4thou. He said upto around 20psi.....3-3.5thou....and after 20psi = 4thou.
Old Nov 7, 2001 | 01:49 PM
boosted3g's Avatar
Default Re: piston to wall clearance with forged pistons (Blown90hatcH)
I am planning to run around 15-16 psi on the turbo and then a little NOS with it (maybe like a 75 shot). i have to calll them but from the looks of it I think that the 4 thousandths would be the way to go.
E Town DSM
Jan 31, 2014 01:02 PM
melovesboost
Feb 5, 2007 12:10 PM
SPOOLINmatt
Jan 13, 2006 06:13 AM
95c1v1cs1
Jul 28, 2004 09:44 AM
crx1856
Nov 3, 2003 12:00 AM
