Take a Look at my throttle cable is it OK? ---PLEASE LOOK
Old Nov 6, 2001 | 03:47 PM
NeXtLeVeL_TyPe_R's Avatar
Default Take a Look at my throttle cable is it OK? ---PLEASE LOOK
I just installed a STR manifold with a Ericks 68mm TB (GSR Spec)
The STR manifold doesnt has provisions for the Stock Throttle Cable bracket
I used a fabricated bracket along with the stock
Does it look ok??
Should i change it rigth away or drive around and see how she goes
The idle doesnt change and the TB reaches WOT with no problem
I heard a GSR throttle cable would be better is this true??
Please look and tell me what you think
The bottom pic is of a tee that i am planning to put in to get coolant over to the Icdle control valve on the STR manifold
Does that look like a good idea ??
Please go here
http://www.cleartaillights.com/testpage.htm http://www.cleartaillights.com/testpage.htm
HELP IS GREATLY APPERICATED
Old Nov 6, 2001 | 05:31 PM
OneThirtyEight's Avatar
Default Re: Take a Look at my throttle cable is it OK? ---PLEASE LOOK (NeXtLeVeL_TyPe_R)
I have a venom intake manifold, my shop custom made a bracked for me that goes in near the fuel rail. That may be a soultion.
Old Nov 6, 2001 | 07:36 PM
Blown90hatcH's Avatar
Default Re: Take a Look at my throttle cable is it OK? ---PLEASE LOOK (97blackteg)
Seems okay....you will be able to tell when you drive it how it is.....you might have some poopy throttle repsonse/feel
1slow_ej8
Jun 7, 2007 10:04 PM
MI4$DC5
Mar 12, 2007 03:22 AM
B18C5-EH2
Apr 12, 2005 02:32 PM
Ri5e
Aug 13, 2002 07:59 PM
