Questions of the allmighty B20VTEC???
Old Nov 8, 2001 | 04:31 PM
Stunna BEN's Avatar
Don't call it a comeback
Default Questions of the allmighty B20VTEC???
Is it worth doing? I was thinking of a B18c5 bottom end to replace my gsr bottom end but i see many R owners going to this set up? I am not looking to rev past 8-8500rpm. How reliable is this set up and what kind of power could this set up give me if i have a gsr head and high compression?
Old Nov 8, 2001 | 04:48 PM
Crossett's Avatar
Default Re: Questions of the allmighty B20VTEC??? (Big Carbon)
I raced a guy a couple of weeks ago that had a b20 bottom end with a b16 head. He was running 9.5:1 compression (getting ready for turbo) and a Hondata, shifting at 9500. From 30 to 130 he had about 2 cars on me. And that thing was LOUD
*edit*
Oh yeah, the engine was in a 5th gen hatch
[Modified by Crossett, 7:48 PM 11/8/2001]
Old Nov 8, 2001 | 06:24 PM
Stunna BEN's Avatar
Default Re: Questions of the allmighty B20VTEC??? (Crossett)
Dag...pull really hard? i wonder what one of those type of build ups would be like with like 11.1 compression. Do pistons from the ITR and CTR fit or do i need custom pistons? Would there be serious mods in making one of those motors handle 8500rpm?
Old Nov 8, 2001 | 06:32 PM
DelsolVtec18's Avatar
New User
no ctr and itr pistons wont fit cause the b20 pistons are 84mm and the ctr/itr are 81mm. You'll need stronger rods and arp rod bolts for the block and upgrade valvesprings for the head to safely rev to 8500rpm.
Old Nov 8, 2001 | 06:37 PM
Stunna BEN's Avatar
Default Re: Questions of the allmighty B20VTEC??? (DelsolVtec18)
Good info. Thanx for the info on the 84mm bore. I was affraid of that. Its all good i cna still get high compression pistons for them. WHat kind of times to those lay down with a high compression build?
Old Nov 8, 2001 | 08:01 PM
HXMan's Avatar
To rev that high, not only will you want forged rods and pistons, you may want to check out Z10 engineering and get a crank girdle.
[Modified by HXMan, 11:02 PM 11/8/2001]
Old Nov 9, 2001 | 06:54 AM
Spade's Avatar
Default Re: Questions of the allmighty B20VTEC??? (HXMan)
Basically if you want high rev's on a B20 you have to rebuild the whole thing.
Just sleave and bore the GSR block, you have the base already, the GSR's crank is strong enough the R/S ratio is better than the B20's and it will cost less!!!!
[Modified by Spade, 3:59 PM 11/9/2001]
Way2fst4u
Aug 15, 2009 05:32 AM
type_r_teggy
10
Feb 23, 2009 08:28 AM
Nextelbuddy
May 9, 2005 07:42 PM
danthemang3
Feb 8, 2005 01:35 PM
XxRoCkMaNxNEOxX
Nov 10, 2003 12:31 AM
