How to "tighten slack in steering"
Old Nov 2, 2001 | 10:19 PM
OneThirtyEight's Avatar
Default How to "tighten slack in steering"
My steeting seems to have slack in it. Like its not calibrated right, seems like it feels real light, and has a lot of play in it. Any way to fix this? Just the latest of my suspesion problems
thanks
Old Nov 3, 2001 | 02:09 PM
vhd's Avatar
vhd
Default Re: How to "tighten slack in steering" (97blackteg)
check your bearing and steering play, most likely it will be the inner and/or outer tie-rods, lift up the front end with the tires off the ground and shake the wheel up and down to check for bearing play, shake it side to side for tie rod end play, have someone shake it while you check to see/feel any movement
Old Nov 4, 2001 | 03:09 PM
project_DC2's Avatar
Default Re: How to "tighten slack in steering" (vhd)
I had to same prob. too! Im going to the shop Wed.
Thanks!
Old Nov 4, 2001 | 07:41 PM
InfamousRS's Avatar
Is this your problem? http://integra.vtec.net/tips/steeringadjustment.html
Old Nov 4, 2001 | 07:43 PM
InfamousRS's Avatar
Default Re: How to "tighten slack in steering" (BLK94RS)
Next time I have my car up on stands (thursday to instal my KYB AGXes)I might give it a try. My steering seems a little sloppy compaired to my friends 96.
[Modified by BLK94RS, 4:43 AM 11/5/2001]
Old Nov 4, 2001 | 08:54 PM
Erik_Pb_Foot's Avatar
New User
hummm.. car is on jack stands as we speak.... hummmmm, if only I had time... and someone else on here has already done this without any problems
Old Nov 5, 2001 | 10:54 AM
Jesse H's Avatar
Default Re: How to "tighten slack in steering" (Pb_Foot)
on my crx, 2 of the bolts holding the steering rack in place loosened themselves out...that really made steering vague and off center.
grape1161
Jun 21, 2009 06:41 PM
awdriscol4
Suspension & Brakes
39
Dec 22, 2006 01:15 PM
buzlink
Nov 17, 2005 12:04 PM
AGNSoncite
Nov 14, 2003 01:03 PM
OneThirtyEight
Jan 22, 2002 06:44 PM
