fuel regulator in a 93 dx would be.... where???
Old Dec 22, 2003 | 04:31 PM
HybridEarthquake's Avatar
Default fuel regulator in a 93 dx would be.... where???
is there, and where would it be?
Old Dec 22, 2003 | 06:21 PM
Kamin's Avatar
Default Re: fuel regulator in a 93 dx would be.... where??? (HybridEarthquake)
the fuel PRESSURE regulator is on the end of the fuel rail.
Old Dec 22, 2003 | 06:55 PM
95civicgsr's Avatar
look at the end of your fuel rail on the driver side and you will see it.
Old Dec 23, 2003 | 10:44 AM
Default Re: (95civicgsr)
Thanks!
How often do these go bad? and what syptoms would I have?
Right now I have intermitant chugging, then it feels like I'm out of gas until I go WOT, at which time it takes off like a shot. After it does this for about five minutes, the CEL comes on, and it runs fine. The CEL code is 43, which is fuel supply problem. I have a pump on the way, but I'm still not convinced that will solve the problem.
Thoughts?
Old Dec 23, 2003 | 11:00 AM
Kamin's Avatar
Default Re: (HybridEarthquake)
fuel filter
Old Dec 23, 2003 | 12:48 PM
Default Re: (Kamin)
been changed 4 weeks ago
Old Dec 23, 2003 | 01:49 PM
95civicgsr's Avatar
when was the last time you cleaned your injectors?
Old Dec 23, 2003 | 02:05 PM
ran fuel system cleaner through...can't remember before or after filter change
Old Dec 23, 2003 | 02:41 PM
95civicgsr's Avatar
you may want to pull your injectors out and take a look at them. how many miles do they have on them?
Old Dec 23, 2003 | 02:45 PM
odom shows 154K, bought the car a month ago so......
Old Dec 23, 2003 | 02:47 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95civicgsr &raquo;</TD></TR><TR><TD CLASS="quote">you may want to pull your injectors out and take a look at them. how many miles do they have on them? </TD></TR></TABLE>
What would I look for? I'm not a mechanical idiot, just not spent much time looking at injectors.
Old Dec 23, 2003 | 06:28 PM
onePOINTsix's Avatar
do a arcived search for replaceing a fuel rail, after you get the FR off take the Fuel Injectors out of the intake mani. and wipe the tips of them clean with a rag, they WILL be dirty, after that, buy some FI cleaner and soak them in it for a couple hours. Put it all back together and your good to roll!
Old Dec 24, 2003 | 01:07 AM
Default Re: (Sideout)
sounds good! thanks for the tip, I'll have to give it a try this weekend
Donkeeyyy
Jul 30, 2010 10:29 AM
HybridEarthquake
Dec 23, 2003 10:46 AM
PUSHER
Jul 3, 2003 10:08 PM
integRated109
Sep 12, 2002 06:04 PM
