mini-me and cam timing - help
Old Dec 22, 2003 | 10:26 AM
tgreaves's Avatar
Default mini-me and cam timing - help
I remember hearing that you have to adjust your cam gear like 4.5 degrees either advanced or retarded when using a D16Z6 head on a D15B7 block.. What way do I adjust the cam gear and is the 4.5 degrees correct.. Thanks
Old Dec 22, 2003 | 10:01 PM
BauleyCivic's Avatar
Risky Business
Default Re: mini-me and cam timing - help (tgreaves)
i didnt adjust anything...set the cam gear and crank pulley to tdc...slide the z6 belt on...and its all good...i didnt touch the dizzy...no problems yet pulls fine 15.9 at the track
Old Dec 23, 2003 | 02:38 AM
Mista Bone's Avatar
D Tranny Guru
1/2 tooth for sure, 4.75 degrees
Old Dec 23, 2003 | 05:42 AM
tgreaves's Avatar
Default Re: mini-me and cam timing - help (Mista Bone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone &raquo;</TD></TR><TR><TD CLASS="quote">1/2 tooth for sure, 4.75 degrees</TD></TR></TABLE>
Do I advance the cam 4.75 or retard it..
Old Dec 23, 2003 | 05:49 AM
tgreaves's Avatar
Default Re: mini-me and cam timing - help (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic &raquo;</TD></TR><TR><TD CLASS="quote">i didnt adjust anything...set the cam gear and crank pulley to tdc...slide the z6 belt on...and its all good...i didnt touch the dizzy...no problems yet pulls fine 15.9 at the track </TD></TR></TABLE>
Am i the odd ball drag racer here.. I ran a 15.8 with my crx with a d15b7 dx non-vtec motor and a dx tranny.. I do have my intake port and polished and a gsr throttlebody on it.. I wonder what ill run with the vtec head on it..
Old Dec 23, 2003 | 08:34 AM
Risky Business
Good stuff man **** thats really good...my friend with a CRX Si I/E could only manage 16.0
Old Dec 23, 2003 | 10:56 AM
tgreaves's Avatar
What was the temps when he raced it.. I pulled a 15.8 without nitrous and a 14.85 with a 55 shot.. It was about 55 degrees outside.. Ill post the movie of me running, I beat a guy with a turbo mr2.. He ran a 14.89 and he was pissed.. His car looked brand new and my crx is a multi color beater right now..
Old Dec 23, 2003 | 11:21 AM
Mista Bone's Avatar
D Tranny Guru
how did you install the cam?
If you install the cam "advanced" then you retard the cam gear.
If you install the cam "retarded" then you advance the cam gear.
Old Dec 23, 2003 | 11:27 AM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone &raquo;</TD></TR><TR><TD CLASS="quote">how did you install the cam?
If you install the cam "retarded" then you advance the cam gear.</TD></TR></TABLE>
Ok.. I see now I asked a dumb question.. If its 1/2 tooth off then you can go either way..
Old Dec 23, 2003 | 11:41 PM
Mista Bone's Avatar
D Tranny Guru
the question would only be dumb, if you had to ask it again, and again, and again!
Now the SECRET since I started this mess 6 years ago.
Warm car up, adjust idle to 700 rpm and ignition timing to center mark.
Change cam using a adj. cam gear at zero. Adjust cold lash settings, start car.
Now reset the ignition timing @ 700 rpm, BUT use the cam gear instead of the dist. to change the timing setting.
Sounds simple now doesn't it?
The effects without a cam gear, I tried both settings........
Not bad 135 crank hp from a 102 hp motor with simple bolt-ons. I consider the cam a simple bolt-on.
Old Dec 30, 2003 | 05:52 AM
tgreaves's Avatar
A little confused here..
Ok.. Got it..
Do you mean to adjust the adj. cam gear until I am exact at TDC meaning like 4.75 degrees adv/rtd.. Then im guessing I let the engine cool off and adjust the valve lash.. Is that what you are saying
Well if I just adjusted the cam gear to exact TDC (ex. 4.75 deg adv/ret) and I go and adjust it again to get the ignition timing back into spec well then I would be right back at 0 deg again and be 1/2 tooth off
Old Dec 30, 2003 | 10:03 AM
Mista Bone's Avatar
D Tranny Guru
start with cam gear at ZERO (markings on the gear) when installing the cam, check the lash, THEN set the ignition timing via. the cam gear.
You should be near 4-5 degrees on the cam gear. Using this method you will eliminate and possible error. Like if the marks are 3 degrees of when etched!!!!!
Old Jun 23, 2005 | 08:25 PM
thrty8street's Avatar
Old Oct 15, 2009 | 06:57 AM
SPL KID's Avatar
Can a mini me swapped car ex CRX be timing light adjusted anymore? jumping the plug doesn't seem to work, also how do you read codes now?
Ef4doorwagon
13
May 17, 2014 06:09 PM
gramentz
Feb 22, 2013 08:12 AM
StraightNoChaser
May 31, 2008 04:17 PM
4DRmafia
Aug 14, 2006 09:53 PM
rass1313
Mar 14, 2005 11:20 AM
