Anyone using 20-50wt. synthetic oil?
Old Dec 19, 2003 | 10:16 AM
Tomcat's Avatar
Default Anyone using 20-50wt. synthetic oil?
I currently use 10-40wt. Redline synthetic oil in my ITR. If anyone is using the 20-50wt. what are your impressions? For example is the 20wt too heavy to adequately protect the valve train during a cold start? Can you notice any more power from the heavier oil film?
Old Dec 19, 2003 | 10:19 AM
Jimmy's Avatar
Global Moderator
Default Re: Anyone using 20-50wt. synthetic oil? (Tomcat)
Please do not use 20w 50 thats hella thick.
Old Dec 19, 2003 | 11:00 AM
SOHC_DK.'s Avatar
Default Re: Anyone using 20-50wt. synthetic oil? (USDMDC2)
I use Castrol RS 10-60.. It's the best iv'e tried yet..
Old Dec 19, 2003 | 11:33 AM
nolimits's Avatar
Why would heavier oil give you more power????
Old Dec 19, 2003 | 05:06 PM
Lord Helmet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tomcat &raquo;</TD></TR><TR><TD CLASS="quote">I currently use 10-40wt. Redline synthetic oil in my ITR. If anyone is using the 20-50wt. what are your impressions? For example is the 20wt too heavy to adequately protect the valve train during a cold start? Can you notice any more power from the heavier oil film?</TD></TR></TABLE>
the only time I used 20-50 wt oil was in the desert in the summer months. since it was 115-120 degree in the shade. any other places I wouldn't recommend since 5-30 wt is the widest range recommend by honda.
Old Dec 19, 2003 | 05:43 PM
Kendall's Avatar
I've had a lot of success with the Mobil 1 0w40 synthetic. But my car sees drastic temperature changes regularly (FL to NC and back). I highly recommend it though.
And you should gain power from a better lubricating oil, not thicker oil.
Old Dec 19, 2003 | 05:59 PM
lsvtec hatch05's Avatar
i use 20-50 in my tranny
Old Dec 19, 2003 | 06:02 PM
Kendall's Avatar
Default Re: (lsvtec hatch05)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsvtec hatch05 &raquo;</TD></TR><TR><TD CLASS="quote">i use 20-50 in my tranny</TD></TR></TABLE>
Please tell me that (a) you were being sarcastic, or (b) you have a damn good reason to do so.
Old Dec 19, 2003 | 07:10 PM
Default Re: (dc231)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc231 &raquo;</TD></TR><TR><TD CLASS="quote">Please tell me that (a) you were being sarcastic, or (b) you have a damn good reason to do so.</TD></TR></TABLE>
i'm being serious. i have had absolutely no problems with it all, i am hard as hell on my tranny and i have no grinds, no problems. one of my buddies has ran it in his car for years and he was the one that told me to use it
Old Dec 19, 2003 | 07:33 PM
D-Man's Avatar
Default Re: Anyone using 20-50wt. synthetic oil? (sleeperciv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleeperciv &raquo;</TD></TR><TR><TD CLASS="quote">
the only time I used 20-50 wt oil was in the desert in the summer months. since it was 115-120 degree in the shade. any other places I wouldn't recommend since 5-30 wt is the widest range recommend by honda.</TD></TR></TABLE>
I wouldnt use 5w-30 unless I was driving around in alaska with below freezing weather.Honda also recommends changing your oil every 7500 miles...lol.
I use 10w-30 in temps below 40,15w-40 in temps between 40-80 and 20w-50 in 80+
Old Dec 19, 2003 | 07:55 PM
SIXTYdashONE's Avatar
HT's Biggest Loser
Default Re: Anyone using 20-50wt. synthetic oil? (D-Man)
I use Quaker State Synthetic 20w-50 in my car, i like it alot. my car burns up 10-30 like water, had to change it after every 2-3 runs. i can get at least 8 runs out of 20-50, hehe
Old Dec 19, 2003 | 10:47 PM
Tomcat's Avatar
Default Re: Anyone using 20-50wt. synthetic oil? (SIXTYdashONE)
My ITR also burns a fair amount of oil when I use 5w-30w oil. It uses only a small amount when using 10w-40w.
Old Dec 25, 2003 | 11:32 PM
Rowdy's Avatar
This sounds like a good question for Dennis at LDL, see sig.
Old Jan 5, 2004 | 12:56 PM
Tomcat's Avatar
Default Re: Anyone using 20-50wt. synthetic oil? (Rowdy)
Thanks Derek,
I'll give Dennis a call...
Old Jan 5, 2004 | 03:13 PM
EG-lowrider's Avatar
tidbit of info for people who may not know how to read oil viscositys.
first number = cold \ startup weight
second number = warm weight
ie = 5w30, 5 weight when you start the car when cold, then when the engine warms up, the viscosity changes to 30 weight,
thought some of you would find that interesting. and if you dont believe me, ask my automotive teacher!
Old Jan 5, 2004 | 06:56 PM
Rowdy's Avatar
Default Re: (Broke@$$tuner)
Your teacher is correct.
Go buy him/her a
Old Jan 5, 2004 | 08:45 PM
blackeg's Avatar
Default Re: (Rowdy)
20-50 is like sludge. all my vw friends use it and make fun of me for 5-30 saying it dont work. go with what honda reccommends, after all they did make the car
Old Jan 5, 2004 | 09:04 PM
Rowdy's Avatar
vw, whats that?
Old Jan 6, 2004 | 08:06 AM
blackeg's Avatar
Default Re: (Rowdy)
volkswagon. it reccommended for volkswagons, but i wouldnt let 20-50 near my honda
Old Jan 6, 2004 | 08:14 AM
Rowdy's Avatar
I was just being a little sarcastic, about the vw slam.
I like to use whatever oil the Factory reccomends, (or whatever the engine builder I deal with tells me).
Old Jan 6, 2004 | 09:41 AM
ejprimo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Broke@$$tuner &raquo;</TD></TR><TR><TD CLASS="quote">tidbit of info for people who may not know how to read oil viscositys.
thought some of you would find that interesting. and if you dont believe me, ask my automotive teacher!</TD></TR></TABLE>
the "W" in the first number has nothing to do with the oils weight. the "W" means winter. you have to pass a the cold cranking viscosity test in order to be assigned a 0w, 5w, or 10w.
0W cold cranking vis. must be better than 6200cp@-35C
5W cold cranking vis. must be better than 6600@-30C
and if 5w was an indication of the oils actual viscosity when cold, then that would mean that oil thickens up as it gets hotter, when in reality oil get thinner as the temperature increases. a 30weight oil is only a 30wt. at 210F and as the oil temperature rises it becomes even thinner.
Old Jan 6, 2004 | 02:18 PM
Rowdy's Avatar
Default Re: (ejprimo)
Great info.
Old Jan 6, 2004 | 02:38 PM
Shadow Templar's Avatar
Default Re: (Rowdy)
the only car i ever used 20-50 was in my 84 RX-7. The rotors were specially equipped with aftermarket apex seals and all this happy horseshit that i built into it. very tempermental engine! even during summer it ran best with 20-50.
Old Jan 6, 2004 | 04:34 PM
Two_K Si's Avatar
Default Re: (Shadow Templar)
I use to use only 5w-30 oil until i saw the oil reccomendations for my engine in japan and europe. Other countries are allowed to use 40 weights, 50 weights, even straight weights. Makes you wonder why N. America is only allowed to use 5w-30.
gooblinn258
May 12, 2014 10:54 AM
bowtieboy911
Jul 13, 2011 06:43 AM
hurleyrob
17
Jun 30, 2006 09:14 PM
itr1244
Oct 30, 2004 12:08 PM
HUBB
12
Apr 24, 2004 01:53 PM
