Change Transmission Fluid After Grind?
Old Dec 20, 2003 | 09:51 AM
baphomet's Avatar
Default Change Transmission Fluid After Grind?
I had a little mishap, and gave second a grind. Should I change the transmission fluid now?
I ask because the grind has me thinking about metal particles floating around in my transmission. I don't know......Should we change our transmission fluid after grinding a gear or am I being to paranoid?
Old Dec 20, 2003 | 07:46 PM
kommon_sense's Avatar
Default Re: Change Transmission Fluid After Grind? (slashDEVslashNULL)
I think that you are being a little paranoid However if you are concerned, you can always get one of those tranny drain plugs with the magnet on the end.
Old Dec 20, 2003 | 08:00 PM
Muckman's Avatar
Moderator in Chief
holy chit man your way too paranoid. you prob rebuild your engine when you hit the fuel cut off. your transmission is fine.
Old Dec 21, 2003 | 09:43 AM
baphomet's Avatar
Default Re: Change Transmission Fluid After Grind? (Muckman)
lol thanks. Do local auto shops carry magnetic transmission plugs? I believe I saw oil before. I don't want to pay jacked up prices for a jdm name. BTW, the transmission has an internal magnet right?
dankoty
Honda CR-V & Element
11
Jan 8, 2017 03:38 PM
honda.girl.1991
Jan 16, 2014 08:36 PM
baiwldrnner
Honda Civic (2001 - 2005)
Jul 18, 2007 09:55 PM
vietintegboi
Sep 7, 2006 02:32 PM
Turtle
Jan 3, 2002 05:15 AM
