Ls/vtec build finished now for the problems???
Old Dec 24, 2003 | 06:07 PM
MysteryWagon's Avatar
Default Ls/vtec build finished now for the problems???
Bugs begining with: No wires are crossed, when car is running cold no missfires, after warm up if you get on it to much temp gauge drops to cold, vtec does not come in good it sounds and feels real speratic if that is a word. Then the missfiring begins and it is uncontrolable.
But, this is where the crazyness begins. The distributer timming when set close to stock and everything straight like TDC and camgears in the correct spot runs like crap and when driven the tinning changes and goes way off. Then after switching the C1 and C2 crankangle sensor wires and tunning it near 20 degrees timming it runs desent, not best but desent. Any suggestions would be greatly appriciated.
plese please help
built bottom
rebuilt head, camgears, stockcams
what is up
thanks
Old Dec 24, 2003 | 10:49 PM
1.8turbolsvtec's Avatar
Default Re: Ls/vtec build finished now for the problems??? (MysteryWagon)
ok you say that your timing is 20 stock is between 14 and 16 . if it is missfireing it is rick 20 is advansed timing that is why it runs better.cheque the timing belt to see if the timing belt is on timing look for the marks on the crank and on to cam gears . and a ? do you have a afc or vafc or any fuel controller .i build them motors all the time there are fun but then need to be tuned well ok.if you want you can im me lsvtec1975 that is me turbo ls vtec 523 hp at 23 psi with hondata and a 62-1 turbo
Old Dec 24, 2003 | 11:43 PM
xsiv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MysteryWagon &raquo;</TD></TR><TR><TD CLASS="quote">Then after switching the C1 and C2 crankangle sensor wires </TD></TR></TABLE>Why would u switch those wires?
First of all, are u throwing any codes? If so, what are they?
Old Dec 27, 2003 | 07:52 PM
Default Re: Ls/vtec build finished now for the problems??? (xsiv)
code 9 and 24. The temperature thing is really anoing, I donot understand why it does what it does.
engine is getting right around 50psi from FPR.
also running around 8.5 compression.
Old Dec 27, 2003 | 08:20 PM
Sliced Beard's Avatar
50 psi is your answer
i run my engine around 42 psi
i think you should get your car proffesionally tuned by someone who has done this a time or two and get them to show you what to do as they are doing it. imho
you shouldn't be running anything near 50psi but more like 40-43psi
also keep the wires the same do not reverse them
here is a good link for you it is a b20/18 vtec guide and a bunch of other stuff
http://www.c-speedracing.com/howto.php
just look around and it will tell you exactly what to do
808DB1
Mar 15, 2008 09:44 AM
sirdj
Jul 10, 2007 12:02 PM
dohcgarage@714
Mar 19, 2007 10:45 PM
ewn1603
Sep 25, 2004 06:22 AM
made in JAPAN
Oct 26, 2003 08:09 PM
