Motor Oil in Transmission?
Old Dec 18, 2003 | 10:07 PM
Combustion Contraption's Avatar
Default Motor Oil in Transmission?
A guy whose opinion i respect and trust told me he has been using Mobil 1 Synthetic 10w-30 in honda trannys for as long as he can remember, it works great and hes never had any problems. since im finishing up my swap right now i was wondering if this was an ok idea to try out? anyone else ever try this?
Old Dec 18, 2003 | 10:10 PM
Elitoh1's Avatar
Default Re: Motor Oil in Transmission? (LsVtec92Hatch)
i use reg. 10w 30
dont use gear oil.
Old Dec 18, 2003 | 11:11 PM
i wasnt going to use gear oil. anyone else?
Old Dec 18, 2003 | 11:52 PM
OnebadJdmEg6's Avatar
From: being tracked by FAGS Docking PERCENTAGES, GAYFUKS
Default Re: (LsVtec92Hatch)
i use Mobile 1 10w-30 in my z6 tranny nothing is wrong with it sometimes i just change it often now and then just to keep my tranny and a good condition.
Old Dec 19, 2003 | 03:06 AM
SIXTYdashONE's Avatar
HT's Biggest Loser
Default Re: (OnebadJdmEg6)
I use 10-30 in my track car since day one, no problems whatsoever.
Old Dec 19, 2003 | 03:33 AM
D-Man's Avatar
its ok,I use castrol 10w-30 gtx synthetic with no problems in 50,000k
Old Dec 19, 2003 | 09:02 AM
Devlins 91LS's Avatar
Default Re: Motor Oil in Transmission? (D-Man)
In older hondas (like pre-94) honda hadn't invented MTF yet, so they suggested running motor oil in it. I use GM Syncromesh Friction Modified and its the smoothest shifts ever. Even with a SS installed.
Only downside, the ish is like $15/qt
Old Dec 19, 2003 | 09:22 AM
sweet. Thanks for the replies guys. I appreciate it.
Old Dec 19, 2003 | 01:27 PM
92civeg's Avatar
i ran 10-w-30 for a year and last week i switched to gm syncromesh friction modified..oh boy what a difference...i would suggest to just use the syncromesh
Old Dec 19, 2003 | 07:24 PM
X2BOARD's Avatar
Default Re: (92civeg)
I only use Genuine Honda MTF. It's formulated for the Tranny... motor oil will cause premature wear.
Old Dec 19, 2003 | 08:27 PM
slammed_93_hatch's Avatar
Default Re: (X2BOARD)
deffently use honda MTF or some other MTF i did use motor oil in my old tranny felt like **** new tranny, with MTf ***** like BUTTA
Old Dec 19, 2003 | 10:17 PM
NitrousB.I.G.'s Avatar
Default Re: (slammed_93_hatch)
Do not use regular motor oil!!!! Use Honda MTF your syncros will thank you. If you have a Honda LSD and use regular motor oil it will ruin the LSD. In closing only use Honda MTF or you may ruin your tranny. I havent personaly used the GM syncromesh but I have heard that it works just as well.
Old Dec 20, 2003 | 09:40 AM
Default Re: (NitrousB.I.G.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NitrousB.I.G. &raquo;</TD></TR><TR><TD CLASS="quote">Do not use regular motor oil!!!!</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by X2BOARD &raquo;</TD></TR><TR><TD CLASS="quote">motor oil will cause premature wear.</TD></TR></TABLE>
Honda did when it shipped out its DA and DBs. Sure there are better transmission fluids out there, but if it was such a problem, don't you think honda WOULDN'T have done it?
Old Dec 20, 2003 | 11:34 AM
Mikey3000's Avatar
where do u get this GM Syncromesh from?
Old Dec 20, 2003 | 11:59 AM
hybrid901's Avatar
Default Re: (Mikey3000)
Old Dec 20, 2003 | 01:09 PM
SimbaDogg's Avatar
Default Re: (hybrid901)
i'm gonna change my tranny fluid today, but i just wanted to know is the fill plug any different (or in a different location) from the the usdm d series trannys? does the fill plug use the 3/8 in drive from a socket, or is it something else? this is on a jdm s1 cable tranny by the way
Old Dec 20, 2003 | 07:43 PM
kommon_sense's Avatar
Default Re: (SimbaDogg)
Genuine Honda MTF or Redline MTL/MT-90.
Old Dec 20, 2003 | 07:58 PM
Muckman's Avatar
Moderator in Chief
Default Re:
GM Synchromesh MTF here.
Old Dec 21, 2003 | 07:17 AM
RTst's Avatar
on my 92 civic, filling plug was 17mm. What you're talking about is drain plug. If you're looking at the drain plug dead straight, fill plug is to the left and up about 4".
As far as using motor oil....
I replaced my axles yesterday, and I filled it with 10W30. The repair manual says to use 10W30, so that's what I used. It worked well for 220,000km so it should work fine now.
Old Dec 21, 2003 | 12:02 PM
h22 civic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mikey3000 &raquo;</TD></TR><TR><TD CLASS="quote">where do u get this GM Syncromesh from? </TD></TR></TABLE> what he said????????????
Old Dec 21, 2003 | 12:41 PM
AzG35's Avatar
Default Re: (Devlins 91LS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Devlins 91LS &raquo;</TD></TR><TR><TD CLASS="quote">
But you notice how often these trannies grind? Honda MTF would be the minimum fluid I would run. If you read the factory manual, it says 10w30 can be used, but only as a temporary solution. Honda recommends the Honda MTF. I used it with no problems. The GM synchoshift works well too, that is what I am running right now. You can usually get it at any GM dealership.
Old Dec 21, 2003 | 01:32 PM
Kendall's Avatar
Default Re: (AzSi22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AzSi22 &raquo;</TD></TR><TR><TD CLASS="quote">The GM synchoshift works well too, that is what I am running right now. You can usually get it at any GM dealership.</TD></TR></TABLE>
My local dealership will get a visit from me this week. Thanks a lot.
Old Dec 21, 2003 | 05:48 PM
SKDRCR's Avatar
Default Re: (h22 civic)
yeah you can find gm synchromesh at any gm dealer
Old Dec 21, 2003 | 07:20 PM
Default Re: (SKDRCR)
Is the GM Synchromesh a GL-4 or GL-5 based lubricant? Everything that I've read states that GL-5 lubricants are bad for the synchros in a honda tranny.
Old Dec 29, 2003 | 06:41 PM
CleenSi
Guest
Posts: n/a
Default Re: Motor Oil in Transmission? (Devlins 91LS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Devlins 91LS &raquo;</TD></TR><TR><TD CLASS="quote">In older hondas (like pre-94) honda hadn't invented MTF yet, so they suggested running motor oil in it. I use GM Syncromesh Friction Modified and its the smoothest shifts ever. Even with a SS installed.
Only downside, the ish is like $15/qt</TD></TR></TABLE>
if you live in SoCal, head down to miramar pontiac...they have it for $9.31/QT
91grape
Transmission & Drivetrain
21
Jul 31, 2012 11:48 AM
83rolla
Dec 28, 2011 07:46 PM
94Vtecluder
May 31, 2004 02:13 PM
paybac4223
Mar 12, 2003 04:41 PM
wizzards581
12
Mar 6, 2003 11:15 AM
