i need help bad
Old Dec 22, 2003 | 03:00 PM
strizzy's Avatar
Default i need help bad
i have a 89 honda civic lx 194000... the car has a hollow out cat and a cold air intake. the car is runing rough just happen a day ago..does anybody have anyideal what were cause it to run rough. i replaced the plug but no help.any help thanks
Old Dec 22, 2003 | 03:35 PM
VTECorona's Avatar
Default Re: i need help bad (strizzy)
Check your cap\rotor, plugs\plug wires, and if all else fails do a compression test.
Old Dec 22, 2003 | 03:53 PM
strizzy's Avatar
the car runs fine when you go above 2500 it sound like nuttin wrong and the car doesnt smoke. y would all of sudden it will run like that ? and the the check light comes on when on the highway and only on the highway they said it a o2sensor
Old Dec 22, 2003 | 03:56 PM
Kendall's Avatar
It very likely is the O2 sensor. Replace it and let us know.
Also, welcome to Honda-Tech.
Old Dec 22, 2003 | 05:50 PM
fulldragcrx's Avatar
whoa, let not just throw parts at a car here people. Go buy a Hayes/Helms manuel on your car and go thru the testing directions for the o2, if its bad then replace it. Hate to see you spend 45.00 on a o2 if it dont take care of the problem.
Old Dec 22, 2003 | 08:22 PM
leadfoot78's Avatar
Default Re: (fulldragcrx)
Check the code, if it is o2 than check the wiering from the sensor to ecu than u can think of replacing the o2. If its not the o2, it maybe cap and rotor, timing is off or dozens of other things.
Old Dec 23, 2003 | 12:37 PM
strizzy's Avatar
does any body know where the ignitor is and how to test it ?
Old Dec 23, 2003 | 04:11 PM
leadfoot78's Avatar
Inside the distributor, those things are known to take a **** suddenly. I think it's on the right side of the rotor, inside the distributor, if I remember right mine was made by NEC.
Old Dec 27, 2003 | 02:57 PM
strizzy's Avatar
Default Re: i need help bad (leadfoot78)
i found out what was wrong it the distritor any way i can rebuild it
bmoreb18c1
Aug 13, 2012 01:14 AM
spooledhonda
Apr 29, 2006 08:50 PM
ITR 2K
Feb 2, 2002 11:25 AM
jdmrealm
Dec 10, 2001 08:39 AM
maxxdout
Nov 29, 2001 07:38 PM
