When buying a full engine swap is it best to get new?
Old Dec 18, 2003 | 04:56 PM
Chikelu98's Avatar
Default When buying a full engine swap is it best to get new?
I saw someone just recently who was selling a Honda H22A Vtech Engine swap that had low mileage on it. He was selling for $2,100. I have a 91 Honda Civic Lx, I was told that I should probably get a LS motor or a B16 engine swap. But I heard H22's were real good, but I would have to get some welding done to fit it into my engine.
What I wanted to know, is: Should I go ahead and purchase this or get a new H22?
Old Dec 18, 2003 | 05:05 PM
Mohudsolo's Avatar
Default Re: When buying a full engine swap is it best to get new? (Chikelu98)
Price out everything you would need to buy new to do the swap and then compare to the used parts. Complete motor, starter, alternater, transmission, axles, flywheel and clutch, intake manifold, injectors, complete wiring harness, clutch hydraulics, assorted sensors and I forget whatever else. Used parts are always a crapshoot where you hope they are OK. The advantage of course is the cost.
Old Dec 18, 2003 | 05:08 PM
Kendall's Avatar
First off, good luck affording a new H22 as a complete one new from Honda will probably cost somewhere around six or seven thousand dollars for just the motor. Then you need a transmission, manifolds, wiring, ECU, axles, dizzy, throttle body, etc, etc, etc.
Do yourself a favor and find a reputable engine importer and you should be able to find a reasonable price on a complete swap.
Also do some research and take some time to figure out which engine will suit you and your car the best. Don't buy an engine because someone else said is was good.
Old Dec 18, 2003 | 05:09 PM
Chikelu98's Avatar
Default Re: When buying a full engine swap is it best to get new? (Mohudsolo)
yeah, your right about that...I appreciate it...
Old Dec 18, 2003 | 05:11 PM
Kendall's Avatar
Also remember that a lot of engine importers will offer some kind of warranty on the motor, so you shouldn't have to worry.
Old Dec 18, 2003 | 09:47 PM
Don Napier's Avatar
Import Alliance
Default Re: (dc231)
that swap is a pain. Just do a b16 or b18a. it is so much easier. obd0 still too.
Old Jan 1, 2004 | 05:12 PM
ACCORDPOWER97's Avatar
Default Re: (egCivicDon)
i got a used h22a from http://www.total-boost.com/?id=15563 for my accord. awesome quality great price really knowledgeable they also have b series motors for sale. ive usually seen b series swapped in that kind of car but with the right amount of $$ im sure the h22 can be put in
nucar4me
Mar 5, 2011 07:59 AM
777
Northern California (Sales)
17
Jul 10, 2009 07:09 PM
mattwl
Honda Civic (2001 - 2005)
Oct 23, 2008 05:30 AM
IcebergMan
Jun 6, 2006 10:07 PM
fallingfrominfinity
Mar 4, 2004 04:04 PM
