i think my rings maybe gone
Old Dec 19, 2003 | 09:41 AM
mike5809's Avatar
Default i think my rings maybe gone
Well i noticed recently that when i shift above like 6500 esp when i shift about 8k that as soon as i am inbetween shifts that a puff of blue smoke comes out. it used to be black smoke and it used to backfire (im running really rich) but now im noticing blue smoke..it doesnt smoke when getting on it just when in transition from gears...during the shift. when i let off the gas
i did a compression check just last week, and the number were outstanding...
but im still pretty sure that its my rings, i dont think my rings ever seated right, plus ive heard some bad things about forged pistons. and i burn alittle bit of oil
damnit i hate cars...
u guys think its rings?
Old Dec 19, 2003 | 10:15 AM
Jimmy's Avatar
Global Moderator
Default Re: i think my rings maybe gone (mike5809)
Could be your valve stem seals. Maybe
Do a leak down test and come back
Old Dec 19, 2003 | 10:36 AM
ProdriveWRC's Avatar
Default Re: i think my rings maybe gone (USDMDC2)
I would guess valve seals/ valve guides since you say your getting high compression numbers. Oil leaking past the valves won't affect compression numbers but oil still makes it into the combustin chamber.
Alin
Old Dec 19, 2003 | 10:41 AM
mike5809's Avatar
Default Re: i think my rings maybe gone (ProdriveWRC)
well i dont think its in the head. cause when i did valves the seals and guides were replaced.
i think the oil rings are bad and the compression rings are good my .02 cents
Old Dec 19, 2003 | 11:48 AM
AzG35's Avatar
Does it smoke in the mornings on startup? If so, its probably the valve seals. A sign of bad valve seals is blue smoke on startup, and blue smoke on decelleration
Old Dec 20, 2003 | 05:24 AM
hondamanwill's Avatar
If you run rich you can wash the rings and they will not seat properly causing you to blow smoke at high revs.
Redprelude98
30
Jul 21, 2009 01:21 PM
HybridBB6
May 14, 2007 02:36 PM
IGOTpinkShards
May 28, 2004 10:48 PM
Terry_shum
May 1, 2004 05:50 PM
vtec_racer_2kgsr
Jul 17, 2002 05:28 PM
