tire rubbing
Old Jun 8, 2003 | 03:15 PM
avs's Avatar
avs
Default tire rubbing
Currently i am running a stock suspension setup for the 94 integra ls and recently i pick up a set of 16" BBS rims from my friend with a +30mm offset and 7.5" width. Everytime when i go over a corner my rear tire rubs the fenderwall. Could this be my stock suspension being too soft? will upgrading the suspension helps any way ?
Old Jun 9, 2003 | 08:45 AM
avs's Avatar
avs
Default Re: tire rubbing (avs)
anyone?
Old Jun 9, 2003 | 08:49 AM
Aron Parsons's Avatar
I don't know a whole lot about Integras, but most Hondas have an offset of around 35-40. I'd guess the 30mm offset is your problem.
Old Jun 11, 2003 | 09:01 PM
STIBungy's Avatar
My 16x7s are 38mm offset. 30 seems bit too far out and add to that, your rims are 7.5"
Old Jun 11, 2003 | 09:19 PM
tilt's Avatar
with 7.5" rims you want around +45. You can prevent rub by getting really stiff springs in the 450+ range - autox people do this with really wide profile tires. You can try rolling the fenders but +30 might be too much even if you do.
IMHARD2
Aug 18, 2009 11:29 AM
Greg50Lt
Honda Civic (2006 - 2015)
Aug 10, 2007 08:24 AM
zc911
Mar 27, 2007 11:32 AM
bigz187
Oct 20, 2006 08:36 AM
Blackhorse6
Feb 16, 2004 10:02 PM
