header stripped nut, what to do?
Old Jun 8, 2003 | 07:15 PM
Loveless's Avatar
Default header stripped nut, what to do?
well I stripped a header nut, it's on of the 3 between the 4-2 / 2-1 connection of the stock header. AFTER I took everything else too!
I thought I could bypassed it by removing the catalyst convertor but the header mount (near the o2 sensor) is preventing me from taking the whole thing off as one.
Anyways, need advice on what to do next, it's a 14mm but I don't think it'd matter
Also, where can I buy header gaskets?
Old Jun 8, 2003 | 07:25 PM
StyleTEG's Avatar
Default Re: header stripped nut, what to do? (Loveless)
I have had great luck with these
http://www.sears.com/sr/produc...60000
Old Jun 8, 2003 | 08:13 PM
Loveless's Avatar
Default Re: header stripped nut, what to do? (StyleTEG)
I don't think it'll work on me since I need a deep socket
Old Jun 8, 2003 | 08:28 PM
Kamin's Avatar
vice grips+hammer
Old Jun 8, 2003 | 09:40 PM
Loveless's Avatar
Default Re: header stripped nut, what to do? (Kamin)
interesting, I have a question though, what if I can ONLY lock on to the nut by 2 sides of the nut as I do not have enough room to work with. Will I still be able to turn it?
Old Jun 8, 2003 | 10:52 PM
__37__'s Avatar
if the size of it is a 14, try hammering on a 13. try getting some liquid wrench or something like that to help as well. i have done this a couple of times for stripped nuts. the tough part is trying to get the nut out of the socket but that can usually be done by poing a screwdriver threw the other side of the socket. good luck.
Old Jun 9, 2003 | 04:47 AM
StyleTEG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Loveless &raquo;</TD></TR><TR><TD CLASS="quote">I don't think it'll work on me since I need a deep socket</TD></TR></TABLE>
it shuold still work, you slip a deep sock over those and then turn.
Old Jun 9, 2003 | 06:42 AM
integra6650's Avatar
is it a thru bolt i dont remember have had turbo a while if it is cut and replace
Old Jun 9, 2003 | 08:01 AM
mugen76's Avatar
find someone with a metrinch socket set. i have one. it takes off stripped nuts and bolts.
Old Jun 9, 2003 | 08:30 AM
owen_the_soyboy's Avatar
Default Re: (mugen76)
vice grips
or dremel that thing in half
prejdmlude
Nov 11, 2006 01:28 PM
usdmcrx
Feb 26, 2004 09:32 PM
CereaLand
Jun 8, 2003 02:09 PM
Mikes01GSR
Aug 21, 2002 10:24 AM
flat-blk-HB
Jun 15, 2002 03:19 AM
