Cel code 65
Old Jun 11, 2003 | 02:30 PM
CereaLand's Avatar
Default Cel code 65
I pulled a CEL off of my car today. I got a code 65, which is a secondary oxygen sensor heater? How do I fix this? Change the secondary o2 sensor?
Old Jun 11, 2003 | 02:38 PM
acuracing's Avatar
Default Re: Cel code 65 (CereaLand)
Mine came on because I soldered the wrong wires together. Once I solved that problem it never popped up again.
Old Jun 11, 2003 | 02:46 PM
dgonzals's Avatar
From: The Land Of Car Thieves/Rising Gas Prices Daygo, CA, US
Default Re: Cel code 65 (acuracing)
Results for code: 65
Manufacturer
Honda - Engines: 1.5L - (D15B1, D15B2, D15B6, D15B7, D15B8, D15Z1) 1.6L - (B16A3, D16A6, D16Z6) 2.0L - (A20A3, BS, BT, B20A5) 2.1L - (B21A) 2.2L - (F22A1, F22A4, F22A6, F22B1, F22B2, H22A1) 2.3L - (H23A1) 2.7L (C27A4)
Description: Rear Heated Oxygen Sensor Heater
Old Jun 11, 2003 | 04:02 PM
CereaLand's Avatar
Default Re: Cel code 65 (dgonzals)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dgonzals &raquo;</TD></TR><TR><TD CLASS="quote">Results for code: 65
Manufacturer
Yea, thanks, but is there any other solutions that you people recommend?
Old Jun 11, 2003 | 04:35 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CereaLand &raquo;</TD></TR><TR><TD CLASS="quote">
You can check the resistance of the o2 heater. It should measure 4 to 10 ohms. (If you want to be sure that's the problem.)
Old Jun 12, 2003 | 07:28 AM
JimBlake's Avatar
Default Re: Cel code 65 (Chiovnidca)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">You can check the resistance of the o2 heater. It should measure 4 to 10 ohms. (If you want to be sure that's the problem.)</TD></TR></TABLE>
If it's OK then you can check to see that the heater terminals are getting 12v power. If they're not, you can look for a blown fuse or broken wires.
The code says that the heater circuit isn't working. You still have to find what's broken.
kuks24
11
Jun 24, 2019 04:59 AM
xnvb
Aug 31, 2008 08:07 AM
EM1-23
May 25, 2007 02:36 PM
dcfour
May 15, 2005 12:26 PM
agent marlon
Feb 18, 2003 01:54 PM
