Piston Ring ?
Old Jun 11, 2003 | 07:18 AM
x2gold's Avatar
Default Piston Ring ?
The ring-lands on new pistons, esp. forged are suppose to be stronger and thinker. Should the rings be the same size as oem pistons? Or do aftermarket pistons want you to use their brand rings b/c they are larger (in diameter)? Bascially, i'm trying to say, can a STD bore set of rings work on aftermarket pistons, or do you have to buy different size (thickness) rings. Thanks.
thugsbryan
Engine Machining & Assembly
Apr 5, 2018 06:39 AM
thumper64
45
Dec 6, 2016 03:43 PM
EKJOE
15
Mar 31, 2009 07:42 PM
boostedb20z
Feb 10, 2008 12:38 PM
B19CivicHB
Jun 19, 2003 04:15 PM
