best vafc settings??
Old Jun 10, 2003 | 03:54 PM
92civeg's Avatar
Default best vafc settings??
what setting on my apexi vafc would be the best for my 92 b16a civic
......vtec engaugement/af ratio....thanks
Old Jun 10, 2003 | 06:21 PM
godnf8's Avatar
Default Re: best vafc settings?? (92civeg)
you best bet would to take it to a local tuner shop with a dyno and have them tune it correctly. There are no set settings you should use. Every car is different.
Old Jun 12, 2003 | 07:40 PM
Eyes Only's Avatar
Default Re: best vafc settings?? (godnf8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by godnf8 &raquo;</TD></TR><TR><TD CLASS="quote">you best bet would to take it to a local tuner shop with a dyno and have them tune it correctly. There are no set settings you should use. Every car is different. </TD></TR></TABLE>
i second this
Old Jun 12, 2003 | 08:22 PM
PhatOptimo's Avatar
If you have OEM B16 cams the X-over should be @ 5100 or 5200. A general rule of thumb (if you ecu is <U>NOT</U> chipped) is to have it a little lean before vtec and and then go rich after VTEC.
Old Jun 13, 2003 | 11:17 AM
AznPimpS's Avatar
you really need to get it dyno'd and have that as a reference, and VTEC cross over should be right before the low cam dips in power and the VTEC cam should take over ( VTEC x-over)
Old Jun 13, 2003 | 11:21 AM
sivik2nr's Avatar
Default Re: (AznPimpS)
Does anyone here tune it with the 'butt dyno" How's that workin for ya?
Old Jun 13, 2003 | 12:16 PM
94dxt's Avatar
Default Re: (sivik2nr)
search, tragabillions of threads
Old Jun 13, 2003 | 12:59 PM
othick's Avatar
I just hooked up my v-afc about 20 minutes ago. I have only bolt ons on my b16a. I turned the x-over to 5k and it seems to work good. I'm wondering if the computer still gives it extra fuel between 5k and 5.5k or if I need to richen it up? I'm going to the dyno on Tuesday but the more I know when I get there the better.
Old Jun 13, 2003 | 01:18 PM
AzG35's Avatar
Default Re: (othick)
The only real way to get the best settings is with a wideband O2 and a dyno. Otherwise you are guessing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by othick &raquo;</TD></TR><TR><TD CLASS="quote">I just hooked up my v-afc about 20 minutes ago. I have only bolt ons on my b16a. I turned the x-over to 5k and it seems to work good. I'm wondering if the computer still gives it extra fuel between 5k and 5.5k or if I need to richen it up? I'm going to the dyno on Tuesday but the more I know when I get there the better.</TD></TR></TABLE>
Whats up O, this is Charmin. The way the VAFC works is that you can change the VTEC engagement point on the unit, but the ECU still has the same fuel map settings. The VAFC tricks the ECU into thinking it has more or less MAP voltage. So, if you lower your VTEC to 5k and your stock setting is 5.5k, the point between 5-5.5 is unmatched. This is where the VTEC Unmatched fuel settings work. If you look at the VAFC, the Settings menu has a V/T Unmt menu, it will have Hi&lt;&lt;Low and Low&lt;&lt;Hi. Hi&lt;&lt;Low is when you move your VTEC point lower than the factory setting. This adjust the fuel between the 2 points. So in your case, you should richen that point up most likely. The Low&lt;&lt;Hi is just the opposite. Hope this helps.
Old Jun 13, 2003 | 03:05 PM
othick's Avatar
Hey thanks! this thing is a lot different than the s-afc. If I can't figure it out I'll come pester you tonight or tomorrow.
lazerous163
Feb 21, 2007 06:24 PM
callummacd
Mar 27, 2006 12:56 PM
red_ek_hatch
Apr 6, 2005 08:03 PM
integragsr97
Jun 1, 2004 07:38 PM
supernova1400
Dec 14, 2003 10:17 PM
