Injector Q (450cc)
Old Jun 9, 2003 | 04:29 PM
teg92's Avatar
Default Injector Q (450cc)
Lets say an engine is running lean on stock injectors even with the FP maxed out. It needs 310cc injectors.
If I put in 450cc injectors and lowered the FP, is there a chance in hell I'll be able to get in the neighborhood of right A/F ratio with a stock ECU?
Old Jun 9, 2003 | 04:42 PM
poison's Avatar
Default Re: Injector Q (teg92)
Yes, provided with the proper fuel pump.
What car and what fuel pump you running?
Old Jun 9, 2003 | 04:54 PM
teg92's Avatar
Default Re: Injector Q (poison)
For the time being, stock LS fuel pump.
I know for a fact there is enough fuel capable of being delivered for the time being (break in, under 5000rpm). With the MAP sesor unplugged, I am running rich. No matter with what timing and FP with the map sensor attached, I run very lean.
Old Jun 9, 2003 | 05:02 PM
poison's Avatar
What fuel PSI you at? and what FPR you using?
Old Jun 9, 2003 | 08:45 PM
teg92's Avatar
I will run lean with the MAP sensor plugged in all the way to 65-70psi.
With the MAP sensor unplugged, I will be fine even at 45-50psi.
I've got a B&M FPR.
Old Jun 9, 2003 | 08:51 PM
poison's Avatar
Ok, leave the map sensor plugged in, and unplug the FPR vacuum hose.
What is the fuel pressure at?
ITR 05082
Nov 24, 2012 07:22 AM
JDM_EK4_Coupe
Apr 24, 2007 08:19 PM
Acura_I-RS
Oct 24, 2005 05:04 AM
Egone
Nov 19, 2003 06:37 AM
falcongsr
Apr 20, 2002 07:45 PM
