master clutch cylinder install problems
Old Jun 8, 2003 | 11:58 AM
toooslow's Avatar
Default master clutch cylinder install problems
I just installed a new master clutch cylinder for my gsr and put everything back and bled system and stuff, but now the pedal stays to the ground if pushed and dosent pop back up unless i manually pull it back. could this be that i didnt bleed the system right, or the new cylinder is bad or what
Modified by whiteinteg95 at 9:20 PM 6/8/2003
Old Jun 8, 2003 | 12:36 PM
tilt's Avatar
Default Re: master clutch cylinder install problems (whiteinteg95)
you prolly still have air in the system.
Old Jun 8, 2003 | 04:35 PM
integra6650's Avatar
Default Re: master clutch cylinder install problems (tilt)
did you close the bleeder on the slave. it sounds stupid but me and my friend werent paying attention and it was left open so we just kept pumping out good ****
Old Jun 8, 2003 | 04:55 PM
WundedSaint's Avatar
did you bleed the cylinder before you installed it? It sounds like it's bypassing...
Put it on a vice, fill the reservoir with fluid and leave the little plastic cap in that came with it that's in the outlet port. Then push on the piston slowly in until it's in. You should feel some resistance, but not a huge amount. It should move back out when you when you release the piston and feel kind of springy. Then fill it up with more fluid and take the cap off when you're ready to put the line in.
Old Jun 8, 2003 | 06:43 PM
toooslow's Avatar
whats absolutely the best way to bleed the clutch?
Old Jun 9, 2003 | 08:28 AM
toooslow's Avatar
Modified by whiteinteg95 at 3:26 AM 6/10/2003
deathtoinvader0
Honda Civic (2006 - 2015)
Feb 1, 2019 08:30 PM
JDMswagSerf
Dec 10, 2013 09:47 PM
Jonathannx2
23
Jul 2, 2011 11:31 PM
delorean
Jun 26, 2011 06:00 PM
Duck Sauce
Apr 13, 2008 09:30 PM
