I need help bad.
Old Jun 9, 2003 | 07:13 PM
Ivan's Avatar
senior gold member
Default I need help bad.
I use to run a b18b swap in my car. I converted to ls/vtec. now I get a check engine light and no injector pulse width in number 4 cylinder. I tried hooking up the pbd2 scanner to see what codes I would get. I couldn't get linked with the scanner. I even tried to do the jumper to get the codes but no luck. I even tried a different ecu. Any ideas?
Old Jun 9, 2003 | 07:18 PM
poison's Avatar
Default Re: I need help bad. (Ivan)
hmm, that's odd. Could potentially be a bad injector, or faulty wiring.
What injectors are you using?
Old Jun 9, 2003 | 07:21 PM
Ivan's Avatar
senior gold member
Default Re: I need help bad. (poison)
I'm using GSR's. the injectors are good. I tested them. how could the wiring be messed up? I didn't mess with the wiring. It ran fine with my b18b.
Old Jun 9, 2003 | 07:27 PM
Ivan's Avatar
senior gold member
also lets say its the wire that somehow got messed up which I know it didn't. Would that cause the check engine light?
Old Jun 9, 2003 | 07:34 PM
poison's Avatar
Yes, that will not complete the circuit to make a spray into the combustion cylinders.
The #4 Injector uses 2 wires. A Yel/Blk wire which is a positive source (at A25 pinout) and to the power junction harnes (which is located near the brake master cylinder), and also a Yel wire that leads to A2 (assuming you are OBD1).
Check wiring with a Digital Multimeter
HTH
Old Jun 9, 2003 | 07:46 PM
Ivan's Avatar
senior gold member
its obd2. so it would set a cel? umm I just wanna burn this car
thanks for the help poison.
Old Jun 9, 2003 | 07:55 PM
poison's Avatar
np. I hope you get it fixed man. Just remember it's fixable and you'll love it when you fix it.
Old Jun 9, 2003 | 08:02 PM
Ivan's Avatar
senior gold member
also wouldn't an ignitor do the same thing? but then it would be all injectors huh?
anyone else have any ideas?
Old Jun 9, 2003 | 08:04 PM
poison's Avatar
If the ignitor went out, then none of the cylinders would fire.
It COULD be the cap, or the wires, or also a fouled up plug on the #4 cylinder.
Old Jun 9, 2003 | 08:10 PM
Ivan's Avatar
senior gold member
I changed all that so I guess it has to be the wiring somehow even though I don't know why its messed up
Old Jun 9, 2003 | 08:18 PM
Ivan's Avatar
senior gold member
also I almost forgot. Would a bad wire make me go into safe mode? its doing that(safe mode)
poison's Avatar
Yea. Most likely a bad injector or break in the wire.
madscientist12
Jun 10, 2016 11:11 AM
chrysanderson
14
Nov 7, 2010 09:08 PM
TwoKSiR
Sep 14, 2010 03:25 PM
98vtec
12
Feb 12, 2008 03:30 PM
