Clutch lines.....?
Old Jun 9, 2003 | 11:57 AM
2k1_ITR_0736's Avatar
Default Clutch lines.....?
ok heres the deal, i had my motor in my ek, and now that i crashed that shell, i took it all out and dropped it all in my new shell (dc2)
soo the hard line that came off the slave cylinder before wast gonna bolt up to the stock dc2 one. so i cut it in 2 spots, then i patched witha high pressure rubber hose. is that enough hose to make the clutch no disenguage at all? i mean is 18" of hose too much where the rubber might flex just enough to not work the slave enough? should i go an buy the complete clutch line assembly?
Old Jun 9, 2003 | 12:07 PM
jerseybrandon's Avatar
Default Re: Clutch lines.....? (2k1_ITR_0736)
You did bleed the slave cylinder right? You should replace the steel line with another steel line. Doesnt have to be a preformed from the dealer either.
Old Jun 9, 2003 | 12:12 PM
Default Re: Clutch lines.....? (jerseybrandon)
hmm, yeah i bled her good i did. i even compressed the slave cylinder completely witha clamp so that the potential air in there would be out as well..
Old Jun 9, 2003 | 12:20 PM
If you disconnect the line from the slave and depress the pedal does fluid come out? Are there any leaks where you patched the line?
Old Jun 9, 2003 | 12:23 PM
boat loads of fluid come out... i wasted about 3 gallong of fluid bleeding.
Old Jun 9, 2003 | 12:26 PM
Fluid is getting there but slave isnt moving, as long as its not losing pressure somewhere before the slave it seems like a bad slave cylinder.
Old Jun 9, 2003 | 12:32 PM
i just replaced the slave cylinder
(a.k.a. known good as honda would say)
Old Jun 10, 2003 | 04:36 AM
ok, so the lesson is, dont you rubber lines on your clutch, i replaced it with steel line and the bitch was good to go.
RVMIRXZem1
Aug 8, 2018 12:33 AM
90civicbns
Aug 1, 2013 12:50 PM
jdm kidd
Jan 14, 2011 08:22 AM
sideswiped
Jun 13, 2010 01:35 PM
lifeofbean
Jan 5, 2006 05:57 AM
