anyone use a vacuum pump for brake bleeding?
Old Jun 9, 2003 | 12:01 PM
hellas's Avatar
Default anyone use a vacuum pump for brake bleeding?
my first time using the pump. im sure there was no air in the brake lines, but as i was pumping there was a ton of bubbles that wouldnt go away.
when i went back to conventional bleeding, the bubbles were gone.
wondering if bubbles in the line is normal when using a vacuum pump. the instructions say its done when bubbles go into the catch can, which they did
anyone have experience with this? thanks
Old Jun 9, 2003 | 01:51 PM
WundedSaint's Avatar
Default Re: anyone use a vacuum pump for brake bleeding? (hellas)
yes it's normal...the air is entering between the rubber attachment and the bleed screw
Old Jun 9, 2003 | 09:08 PM
blueeg's Avatar
do it all the time. for a shop that is flat rate, its hard to find someone to help unless its hella slow.
Old Jun 10, 2003 | 05:33 AM
JimBlake's Avatar
I've done that. Air gets sucked in through the threads of the bleeder screw. I smeared a great big gob of grease around the base of the bleed screw. That kept the air out.
Old Jun 10, 2003 | 05:37 AM
hellas's Avatar
thanks guys. it makes sense that air was going through the attachment b/c a different amount was getting through with different fittings. i should have clamped it down
i hope it wasnt going through the threads
white90crxhf
Oct 22, 2012 06:31 AM
.Kevin.
Jun 14, 2008 05:46 PM
dank24
11
Apr 2, 2007 09:26 PM
funkfnamna
Mar 2, 2005 08:44 PM
aphex23
34
Aug 5, 2004 04:40 PM
