timing belt for crvtec??
Old Jun 9, 2003 | 09:42 PM
hatchii's Avatar
Default timing belt for crvtec??
which timing belt to use with b20 with b16 head?
Old Jun 9, 2003 | 09:52 PM
1titesol's Avatar
Default Re: timing belt for crvtec?? (hatchii)
GSR t/b, plus water pump. You probably want to use oil pump also.
Old Jun 9, 2003 | 09:59 PM
hatchii's Avatar
Default Re: timing belt for crvtec?? (1titesol)
so gsr timing belt?
Old Jun 9, 2003 | 10:03 PM
1titesol's Avatar
But it will not fit right without the water pump too. CRV's w/p have less teeth.
Old Jun 9, 2003 | 10:15 PM
hatchii's Avatar
can a b16 water pump be used? if so then get a b16 timing belt?
Old Jun 9, 2003 | 10:19 PM
Kataku2K3's Avatar
B16A/B/B18C/1/5 all use the same VTEC water pump... If you use a VTEC water pump then just go with a P72 (GSR) timing belt... If you use a nonVTEC pump then use a PR4 (LS/CRV) t-belt... The B16A's is shorter overall and only works for the B16A because due to it's short deck height of 263mm's as apose to the LS/CRV/GSR's 270mm deck... Hope that helps... Peace
thirsk66
10
May 22, 2013 02:26 PM
Turbo R
Feb 12, 2006 10:14 PM
racingant
Dec 22, 2005 08:11 AM
Hondasaurs
Jul 30, 2003 09:12 PM
turboex
Dec 10, 2002 07:02 AM
