installed gsr cluster now problems
Old Jun 10, 2003 | 09:33 AM
EARLdaSQUIRREL's Avatar
official honda whore
Default installed gsr cluster now problems
well i installed the gsr cluster, had problems with ground, got that fixed, then i got everything to work but the temp gauge, i tried to find out where it goes to but i cant, also when i tried it out, i musta blown a fuse, cuz now my tach and **** dont work, only things that work are the lights to it, and the fuel gauge, turn signals etc. but no temp rpm or mph ??? i need help asap as i cant drive it till i get those fixed
Old Jun 10, 2003 | 09:47 AM
Kataku2K3's Avatar
Default Re: installed gsr cluster now problems (coptzer)
This isn't going to help you right now but I put a GSR cluster into my friend Mike's (jdmDXrex) '88 CRX... I didn't make any diagrams but I'm finally going home from school today so I'll probably work on his car late today or tomorrow (he goes to school here with me but his cars is at home with no motor ) It'll go back in as soon as I redo his engine harness and he gets his new tranny... As long as you can wait i'll be glad to do it... You said everything except ECTG worked before so I assume you had the electronic VSS wired up, etc. Let me know if you need any other GSR gauge cluster pinouts, right now I'll just get your ECTG... Also how come you can't drive till you get them fixed... I also installed Mike's alarm like 3 months ago and I hid it all on the top side of the firewall... We pulled the dash and he drove without a cluster for 4 weeks... Oh well, it's all good... I'll get back to ya... Latez
Old Jun 10, 2003 | 10:16 AM
Default Re: installed gsr cluster now problems (Kataku2K3)
i didnt wanna drive around with it w/o knowing how fast i got, this is because cops are ****** in my area towards import owners, i also got everything fixed and working , but thanks anyways, my problem with the temp gauge was that it needed to be in the 6th slot and i had to repin it
Old Jun 10, 2003 | 10:41 AM
integra6650's Avatar
just follow the speed of others
Old Jun 10, 2003 | 06:15 PM
b18cDC2's Avatar
How hard is it to swap gsr cluster to a civic ex? I never did it before and would like to know how hard is it before i start doing it.
Old Jun 10, 2003 | 06:27 PM
Kataku2K3's Avatar
Default Re: installed gsr cluster now problems (b18cDC2)
It's really easy... All you gotta do is get a diagram for a Civic gauge cluster and another for a Integra... Cut some Integra cluster plugs off any spare car laying around (may require you to go to the junkyard)... It's just like repinning an ECU... I've never done it for a Civic but it's actually gonna be easier then when I did it on the my friend's Rex because you won't have to wire in a electronic VSS... I personally don't like Teg clusters or even cluster swaps but my friend Mike needed in his Rex as he revs higher than 8,000rpm... It'll take a little work to bolt in as I'm sure you are aware of but it'll work... In the EH or EJ you'll lose a bit of the fuel and temperature gauge but it's not that big of a deal... Good Luck!!!
Old Jun 10, 2003 | 06:36 PM
b18cDC2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kataku2K3 &raquo;</TD></TR><TR><TD CLASS="quote">It's really easy... All you gotta do is get a diagram for a Civic gauge cluster and another for a Integra... Cut some Integra cluster plugs off any spare car laying around (may require you to go to the junkyard)... It's just like repinning an ECU... I've never done it for a Civic but it's actually gonna be easier then when I did it on the my friend's Rex because you won't have to wire in a electronic VSS... I personally don't like Teg clusters or even cluster swaps but my friend Mike needed in his Rex as he revs higher than 8,000rpm... It'll take a little work to bolt in as I'm sure you are aware of but it'll work...</TD></TR></TABLE>
Thanks for the info, and only reason i'm swaping cluster is since i did engine swap the civic cluster is not accurate.
DatOneGuy
20
Jan 25, 2015 10:45 AM
B_Swapped93
Jul 18, 2013 03:56 AM
Turbo Dan
May 11, 2008 02:26 PM
ontheline
Jul 16, 2006 09:12 PM
EARLdaSQUIRREL
15
Jun 10, 2003 04:49 PM
