diagnosing low compression
Old Jun 11, 2003 | 10:28 AM
servion's Avatar
Default diagnosing low compression
I'm about to buy a '89 civic dx hatch.... runs fine, few problem but nothing major. The only thing that's really bad is the compression: 180 140 180 180. When I pulled the sparkplugs, the one in the low cylinder was pretty well covered in oil. Would I be correct to assume that it would be the rings? The motor runs like a champ (for a 1.5L, 4 speed), and he says it burns a quart of oil every 3 weeks or so. I can get this car for 200 bucks, so I'm thinking of dropping the oil pan, honing the cylinder in question and re-ringing it (as well as changing the bearings on that one rod) just to have a reliable daily driver. BUT, I don't have the tools for a leakdown test, and I'm concerned it might be something besides the rings... do I need to fear?
Old Jun 11, 2003 | 10:55 PM
servion's Avatar
Default Re: diagnosing low compression (servion)
Old Jun 11, 2003 | 11:04 PM
irev210's Avatar
for 200 bucks, you really cant go wrong.
it could be the valveguides aswell
Old Jun 12, 2003 | 08:04 AM
JimBlake's Avatar
Default Re: diagnosing low compression (irev210)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by irev210 &raquo;</TD></TR><TR><TD CLASS="quote">it could be the valveguides aswell</TD></TR></TABLE>
Valve guides won't drop the compression pressure. They're outside the actual valve when it's closed. They might be the source of the oil, tho.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by irev210 &raquo;</TD></TR><TR><TD CLASS="quote">for 200 bucks, you really cant go wrong.</TD></TR></TABLE>
Yeah... this is true.
Old Jun 12, 2003 | 08:07 AM
1_bad_EF's Avatar
Default Re: diagnosing low compression (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">
yes, yes, yes
Old Jun 12, 2003 | 08:34 AM
servion's Avatar
Default Re: diagnosing low compression (1_bad_EF)
I bought the car. I runs fine, and I can't see any smoke reving it up in neutral or while I am driving... and the compression is low in only that one cylinder. There was oil all over that one plug.
I just don't want to tear it apart and find out it needs $300+ in headworks on a motor that I could find for much less. I could probably get away with driving it as is and even passing emissions, but I want to fix it if I can without expensive headwork.
Old Jun 12, 2003 | 08:42 AM
Chiovnidca's Avatar
A leakdown test will tell you more.
Old Jun 12, 2003 | 09:02 AM
servion's Avatar
Default Re: diagnosing low compression (Chiovnidca)
I don't have a gauge for leakdown... I've got the #'s from the compression test in the initial post... its a cheap car and I want to keep the total investment at a minimum.
Old Jun 12, 2003 | 09:18 AM
arsenaldragster's Avatar
if it drives fine.. leave it!
nekoabandoned
Jul 24, 2006 03:39 PM
mafay2
Nov 11, 2004 07:34 PM
cgap
Jun 18, 2004 01:15 AM
canuck-mx6
Aug 5, 2003 06:22 AM
hmonglonertim
Aug 23, 2002 10:32 AM
