Honing. By hand or by machine shop?
Old Jun 10, 2003 | 12:18 AM
Spoonin's Avatar
Default Honing. By hand or by machine shop?
Which is better to do? Getting a honing tool and using a power drill to hone the cylinders or getting a machine shop to do it. Has anybody ever messed up the cylinders by using a power drill? How much material does it take off?
Old Jun 10, 2003 | 01:35 AM
texan's Avatar
Default Re: Honing. By hand or by machine shop? (Spoonin)
You can do VERY minor surface cleanup with a flex hone, but any sort of alignment honing or real material removal must be done on a suitable machine. Bore dimensions and alignment are a high precision matter.
Old Jun 12, 2003 | 11:41 AM
Spoonin's Avatar
Default Re: Honing. By hand or by machine shop? (texan)
I just got a B18a block that has been sitting outside for a good while. The only rusted part of the block are the cylinders. Are they still good? I was thinking about getting it resleeved.
Old Jun 12, 2003 | 01:15 PM
Rocket's Avatar
Take some steel wool to it to see how well it cleans up. You can hone by hand. Some very knowledgeable peopl I know massage the cylinders by hand with sand paper and this works really well.
But if you don't mind spending $25-$35 then just let a machine shop do it and make sure they do the last step with 400 grit stones with light pressure. Most modern rings like it smooth.
.adam.
Dec 24, 2007 04:34 PM
averyvm
Feb 4, 2007 06:21 PM
Radyjr
Mar 5, 2005 08:13 PM
1BadCvC
Mar 22, 2004 08:05 PM
