Bog out at full throttle..............need help??
I realized two of the three wires going to the tps plug were backwards (g/w to y/w and vice versa, they were cut for some reason). Ever since i corrected the wires my VAFC reads 100% throttle when closed (idle) and at full throttle the engine bogs out and the VAFC reads 0% throttle( throttle % counting downwards now????). I have checked and double checked the VAFC wiring on the r/b tps wire and its correct. And if i put the tps plug wires backwards again, engine bogs out at 1500 rpms, but i can rev past the 1500 and run fine even at 100%throttle all the way to redline. Plus the VAFC reads the throttle % correct too, from 0%(closed(idle)-100%(full). The engine is a 1 gen B16 w/ a p30.
Can anyone please help me with this????.......... its the only thing left i need to figure out so everythings working right.
