Compression questions???
Old Jun 10, 2003 | 12:22 PM
1.8EG-T's Avatar
Default Compression questions???
Kinda new to the all motor thing...would 11.7.1 be very difficult to run street wise(daily)? Any special tuning tips involved here?
Old Jun 10, 2003 | 12:28 PM
joe_bocc's Avatar
Default Re: Compression questions??? (hybridrex)
11.7 should be too hard to run daily. You would definately have to run at least 91 octane gas, but 93~94 may be needed though.
If your car was properly tuned, you could probably get away with 91 octane.
Old Jun 10, 2003 | 01:37 PM
dfoxengr's Avatar
Default Re: Compression questions??? (joe_bocc)
ive seen 13.5:1 on 93 octane street.
Old Jun 10, 2003 | 03:23 PM
civicsitek GanGsTa's Avatar
Default Re: Compression questions??? (hybridvteceg)
11.7:1 is about as high as you can safely run on 91 with stock timing assuming you have no other tuning.
Old Jun 10, 2003 | 05:43 PM
chevyalltheway's Avatar
depends on the cam and tuning. if you have a wide lobe separation it would be tough to run on the street but a narrow lobe separation with a fair amount of overlap should be alright for the street.
Old Jun 10, 2003 | 05:48 PM
one more chance's Avatar
Default Re: Compression questions??? (chevyalltheway)
11.7:1 is fine...just run higher octane fuel.
2k.civic.si
28
Jan 4, 2011 02:48 AM
peanuts8888
Nov 21, 2006 03:19 PM
plan B.
May 28, 2004 08:13 AM
goldfinger
Mar 16, 2004 01:00 PM
teamrushhatch
Jul 16, 2003 04:19 PM
