D16 piston specs...
Old Jun 10, 2003 | 07:21 AM
rattletrap's Avatar
Default D16 piston specs...
Hey Guys,
I threw a D16Z6 head on the D16Y7 engine that is in my '95 Coupe, on Sunday.
I did a compression test last night and recieved 188psi across the board. No variation, which was good to see, but lower than I expected.
So, my question: Does anyone know the piston dome/dish volume for the D16Y7(P2E) ?
Any feedback would be cool...
Old Jun 10, 2003 | 07:50 AM
Kataku2K3's Avatar
Default Re: D16 piston specs... (rattletrap)
I'm not really familiar with SOHC numbers but no variation is great... P2E: compression height = 30.00mm, dish = 3.32mm... I actually still am working on a formula to convert CH and dish to "cc of dome" even though I'm not sure if it is possible... Those are the only numbers I have for your Y7 pistons but if you don't already have a way to convert then I'll work with yours since I have a known static compression... Peace
Old Jun 10, 2003 | 07:54 AM
rattletrap's Avatar
Default Re: D16 piston specs... (Kataku2K3)
Well, I thought I would be over 200psi, but good to see the engine is good.
Given the complex shape of the dish, I think the only option is to 'cc' the dish, or find specs from Honda. Anyone done this?
Old Jun 10, 2003 | 08:43 AM
altoid's Avatar
http://www.knology.net/~jediklc/D.htm
3.32cc dish
Old Jun 10, 2003 | 08:45 AM
rattletrap's Avatar
Default Re: D16 piston specs... (altoid)
That is the depression depth, not the volume...
Old Jun 10, 2003 | 05:30 PM
altoid's Avatar
cubic centimeters (cc) is a unit of volume and the p2e piston has a hole in it 3.22 cc in volume
MrMug3n
Jul 11, 2008 07:13 PM
kornerk12
Jan 5, 2006 07:20 PM
Unlimitationz
Feb 22, 2005 03:47 PM
junkyard racer
Oct 31, 2004 05:32 PM
