help asap
Old Jun 9, 2003 | 03:11 PM
drvfast's Avatar
Default help asap
im in the process of doing a b16b in a 2000 civic ex coupe. the problem we are having is when the car is idleing and u push the gas pedal it shuts off. we are running the civic type r ecu. i think its a vaccum leak but everything seems hooked up. the only wire thats not hooked up is the blue wire which is tack output. by the way we are using the 2000 ex wire harness. any help thanks
Old Jun 9, 2003 | 03:24 PM
drvfast's Avatar
Default Re: help asap (drvfast)
anyone
Old Jun 9, 2003 | 03:28 PM
n1ek's Avatar
how's the map sensor?
Old Jun 9, 2003 | 03:43 PM
drvfast's Avatar
Default Re: help asap (n1ek)
the map is fine checked all the vaccum lines cleaned the iacv with carb cleaner still no luck
Old Jun 9, 2003 | 03:56 PM
poison's Avatar
Check the CEL's bro
MAP sensor readings are most likely screwed, or bad MAP sensor.
Old Jun 9, 2003 | 05:59 PM
Blaze45's Avatar
Brrraaaap!
Default Re: help asap (poison)
If it idles high, its a symtom of a vac. leak, take some propane and open a small opening and run it over your vac. lines. If the idle goes up when your by one you've found your leak.... Is the ECU throwing any codes?
Blaze
Old Jun 9, 2003 | 08:26 PM
drvfast's Avatar
update on the problem we checked the codes. they are map sensor, tps, and iacv. we cleaned the iacv codes still came up. we used the map sensor of the sohc code still came up. what can we do now since we know what the codes are? how do we go about solving the problem.
Old Jun 10, 2003 | 12:02 AM
aeolus's Avatar
soundslike youmight not have connected a ground right somewhere.check your grounds.
carlos8
May 25, 2014 08:08 AM
cleanazcoupe
Engine Management and Tuning
Jul 8, 2009 09:28 PM
racerx3kgt
Apr 12, 2009 07:08 AM
Special B
Sep 13, 2007 12:52 PM
GTEater
Aug 23, 2001 06:23 PM
