Is this normal for a 6 puck clutch?
Old Apr 13, 2004 | 08:06 PM
ITSTOCK's Avatar
Default Is this normal for a 6 puck clutch?
I got what i was told to be an action 6 puck sprung clutch. i got a semi built d16 which im guesisng puts down around 250whp at the moment. Im using the stock flywheel its just been resurfaced. When i shift in the higher rpms from 1>2 and 2>3 it chatters/vibrates pretty bad, feels like something gonna explode. Maybe im just exxagerating? this is my first 6 puck clutch, is this normal?
Old Apr 13, 2004 | 08:25 PM
ensracer's Avatar
there is alot of chatter with 6 puck clutches...
Old Apr 13, 2004 | 10:16 PM
AsianMullet's Avatar
Default Re: (eduardo)
usually only chatter getting into first......usually you can get into the other gears smoothly if you can get used to it.....6 pucks grab like a on/off switch...
Old Apr 13, 2004 | 10:31 PM
APEX CRX's Avatar
Default Re: Is this normal for a 6 puck clutch? (ITSTOCK)
had an ACT 6 puck solid hub, HD pp, 12lb flywheel on my last d16a with a JRSC and it did not chatter in other gears at higher rpms. Only starting in 1st gear with revs low. You better check that **** out before something goes boom.
Old Apr 14, 2004 | 09:02 AM
Crazydave's Avatar
Default Re: Is this normal for a 6 puck clutch? (APEX CRX)
Yes..
Chattering is normal..
I hated mine..
I was always slipping it to make it not chatter..
it soon burned up... and I put a stock clutch back in and fell in love with the stock clutch
there is no need for a 6 puck clutch on a street car
Brandon H.
Nov 18, 2012 09:14 AM
an2ny888
Transmission & Drivetrain
Sep 7, 2010 08:58 PM
lude98SH
Feb 21, 2006 07:28 AM
danny98r
Jun 24, 2004 12:15 PM
98cwitr
Dec 9, 2002 11:43 PM
