B16 problems no fuel to cylinder
Old Apr 14, 2004 | 07:42 PM
PhReAzE's Avatar
Default B16 problems no fuel to cylinder
OK, heres the situation, i just got my b16 out of the shop, when i first got it i was firing on all cylinders, now i am not firing on the one that is on the drivers side. I checked this by pulling the wires off the dizzy one by one, this one had no effect. The first thing i did was to change the plugs, the one pulled from that cylinder was covered in ****. After the plugs were changed, i still was only firing on 3 cylinders, so i checked the wires, the resistance was acceptable. I pulled the plug again, and put a spark plug on the wire grounded it , and it sparked no prblem. The i realized that there is no fuel going into the cylinder, what do i do next? what do i check?
Thanks, Evan
Report Post | IP: Logged
Modified by PhReAzE at 7:03 AM 4/16/2004
Old Apr 14, 2004 | 07:46 PM
zensoku207's Avatar
Check to see if you're pulling any ecu codes by jumping the lil green box underneath the glove box. That might tell you whats wrong with it.
Old Apr 14, 2004 | 08:13 PM
Lysawy's Avatar
Default Re: (zensoku207)
fuel injector..... clogged or took a dump on you..
Old Apr 14, 2004 | 09:06 PM
PhReAzE's Avatar
no codes
Old Apr 14, 2004 | 09:08 PM
PhReAzE's Avatar
Default Re: (PhReAzE)
how do i clean the injector?
Old Apr 14, 2004 | 09:55 PM
zensoku207's Avatar
fuel injector cleaner......?
or check to make sure the injector is plugged all the way in, if not, take off the fuel rail, check the tip for any dirt/grime, clean, install.....round 2.....
Old Apr 14, 2004 | 10:53 PM
PhReAzE's Avatar
any additive you suggest, it is not letting any fuel through
Old Apr 16, 2004 | 08:01 AM
PhReAzE's Avatar
Default Re: B16 problems no fuel to cylinder (PhReAzE)
ok, the injector is fine, i swapped it with the one beside it, and i still have the same problems with cylinder 2? how do i check the wiring, and power?
Evan
Old Apr 16, 2004 | 08:52 AM
FastAllmotorLsVtec
Guest
Posts: n/a
Default Re: (Lysawy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lysawy &raquo;</TD></TR><TR><TD CLASS="quote">fuel injector..... clogged or took a dump on you..</TD></TR></TABLE>
Old Apr 16, 2004 | 10:41 AM
dfoxengr's Avatar
definitely an injector. ive got 4 gsr's forsale for 45 shipped.
davethomson
Dec 9, 2018 04:23 AM
davidbrookstone
Nov 11, 2011 11:38 AM
nisdat720
Mar 7, 2010 05:39 PM
b17 rolla
Jan 17, 2009 03:53 PM
PhReAzE
Apr 14, 2004 07:51 PM
