Is this a possible spun bearing?
Old Apr 14, 2004 | 03:13 PM
eg crunkmonster's Avatar
Default Is this a possible spun bearing?
Well, I just put in this motor and it worked prefectly fine in the car that it was in before (friends GSR before it got totaled). When I put the motor into my car, it started up but would die after i drove it and came to an idle. THen it would take forever to turn back on. I would crank it for like 2-5 minutes and it would finally turn on.
I went ahead and CHANGED EVERYTHING i could think of (map sensor, wiring harness, replaced lighten ACT flywheel with a stock one, ect.). Then i remembered hearing a "tick tick tick" noise coming from the motor but the ticking would be in a constant cycle of ticking and then it wouold stop and tick again, ect ect. So i researched H-T to see if it was a spun bearing,
Now i just pulled my oil pan and was wiggling on all of the rod caps and they wiggled right and left (I dont think thats suppose to happen) HELP!!! is it a spun bearing?
Old Apr 14, 2004 | 05:17 PM
eg6h8k's Avatar
Default Re: Is this a possible spun bearing? (eg cookiemonster)
the rods big ends suppost to move back and forth a little..from that picts its hard to tell..look in the oil pan and around the bottom end and see if theres any shaving...or u could just take off the rods cap...
Old Apr 14, 2004 | 05:31 PM
Default Re: Is this a possible spun bearing? (eg6h8k)
if i take off the rod caps.....is there anything special i have to do except torque them down and how many lbs do i torque them?? I dont see any metallic in the oil so far, ill look at the bottom of the oil pan to chekc if there are any shavings
anyone else??
thanks for the replies
Old Apr 14, 2004 | 06:11 PM
RedlinedVTEC's Avatar
Edit Spelling: If you take the caps off apply some assmbly lube to the bearings and rod journals. Torque the caps to 33 lb/ft.
Old Apr 14, 2004 | 07:37 PM
LudeyKrus's Avatar
While you got it all apart, pull the cap off of that rod and take the bearings out. Inspect them. If it spun the main bearings, then you should be able to see a slight scour or discolored mark from where it had spun.
I don't believe a spun bearing would make it act like that , though.
Old Apr 14, 2004 | 08:00 PM
mmuller's Avatar
Mad Scientist
Default Re: (LudeyKrus)
why dont you just turn the engine by hand, if it turns, then should be ok.
if you cant, then take it apart.
And if you spun a bearing on that rod, then you really would not be able to wiggle it since it would be kinda sized up
Old Apr 14, 2004 | 08:30 PM
Default Re: (mmuller)
i spun the crank....it spins prefectly fine
Old Apr 14, 2004 | 08:40 PM
d16y8turbo's Avatar
if you take off the rod caps you can tell if there's a spun bearing by the little tabs on the bearings. if they're flattened out, then it spun...if not then you're good.
Old Apr 14, 2004 | 09:09 PM
Dammit_Dan_954's Avatar
Sounds more like an issue with your head. Try doing a valve adjustment.
LudeLooker
Jun 21, 2013 03:08 PM
Baron55
Jan 9, 2007 08:10 AM
Unsivil_audio
Jan 19, 2005 11:23 AM
eg crunkmonster
30
Apr 15, 2004 01:46 PM
jdmcivicferio
Mar 16, 2003 06:54 AM
