How to fix a coliover thread?
Old Apr 15, 2004 | 06:26 PM
TedR719's Avatar
Default How to fix a coliover thread?
I have a oppertunity to get some nuespeed coilovers for cheap but the problem is that the guy selling it does not have the top nuts for them, we tried to put them on with the stock nuts and end up stripping the threads on one of the front ones.
Can I get the threads fixed? The one is pretty bad to where we took a little chunk out of it so it cannot be re threaded.
Old Apr 15, 2004 | 07:18 PM
TedR719's Avatar
Default Re: How to fix a coliover thread? (futuresi)
Here is the part I'm talking about
Old Apr 15, 2004 | 07:29 PM
VtecDeMoN's Avatar
Wow, don't know what to tell you... should have just gone to a hardware store and looked for some nuts that fit...
Brian
Old Apr 15, 2004 | 09:04 PM
dmotoguy's Avatar
Default Re: How to fix a coliover thread? (VtecDeMoN)
call the manufacturer and see if the whole rod can be replaced or if you need to replace the whole shock.
Old Apr 15, 2004 | 10:22 PM
XSIintegra's Avatar
your looking at replacement of the whole shock.
Old Apr 16, 2004 | 07:43 AM
dat_flip's Avatar
Default Re: (XSIintegra)
go find a thread file and clean it up or get the proper pitch die to clean it up
Old Apr 16, 2004 | 08:17 AM
Sliced Beard's Avatar
Default Re: (dat_flip)
if i am correct the thread pitch is 10x1.25mm
just get a good die and clean it up
but i would seriously reccomend using the correct size nut next time
Old Apr 16, 2004 | 08:53 AM
MightyMouseTech's Avatar
Default Re: (dirtyd463)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dirtyd463 &raquo;</TD></TR><TR><TD CLASS="quote">if i am correct the thread pitch is 10x1.25mm
but i would seriously reccomend using the correct size nut next time</TD></TR></TABLE>
I would not recommend doeing this. If the thread is damaged, replace the rod if possible, if not replace the shock. If that thread ever fails while you have the shock out of the car, it is going to launch the upper spring perch through whatever it is closest to, including people. Never mess around with loaded springs and questionable hardware.
Old Apr 17, 2004 | 11:09 PM
Default Re: (MightyMouseTech)
the only reason why i suggested this fix was because it was on a coilover setup
when coilovers are off of the vehicle the spring has no actual load on it because of how short it is unless you have your car jacked up like a truck
Old Apr 18, 2004 | 07:41 AM
StyleTEG's Avatar
Replacing the rod would no doubt have to be done in conjunction with a rebuild, at which point I am willing to bet costs more than the shocks themselves. (if they are rebuildable).
Old Apr 18, 2004 | 02:19 PM
TedR719's Avatar
Default Re: (StyleTEG)
Yeah so I guess I should just save for a new pair. They are the full threaded nuespeed coilovers so the whole thing would need to be replaced.
Old Apr 18, 2004 | 05:34 PM
StyleTEG's Avatar
Default Re: (futuresi)
Ah actually the neuspeed are koni yellows if I am not mistaken.
They can be rebuilt/revalved for around $100 a shock.
Probably cheaper than replacing.
Old Apr 19, 2004 | 07:00 AM
TedR719's Avatar
really?, so they do seperate? If so then I will just do that. I thought the full threads are just all one piece, is that not true for the nuespeed coilovers?
Old Apr 19, 2004 | 07:04 AM
TedR719's Avatar
these are what the coilovers look like
SicTransitJosh
Group Threads
11
Apr 9, 2010 06:52 PM
STREETWERKZclothing
Northwest
124
Dec 8, 2007 01:45 AM
razorskater
Jan 22, 2006 12:29 PM
TedR719
Apr 15, 2004 08:33 PM
