vafc install help!
Old Apr 14, 2004 | 01:21 PM
JBk24crx's Avatar
Default vafc install help!
i searched and couldn't find much to solve my problem, the install is for a 96 civic 2000 usdm itr motor in with obd2-obd1 harness and p28 mugen chip, i installed the vafc following the instructions by a'pex manual and the check engine light remains on , does anybody had this problem before? any advise will be very helpful. thanx
one more thing i installed the vafc to the car stock obd2 harness.
Modified by JBLSVTEC at 10:33 PM 4/14/2004
Modified by JBLSVTEC at 10:35 PM 4/14/2004
Old Apr 14, 2004 | 02:38 PM
JBk24crx's Avatar
bump for advice
Old Apr 14, 2004 | 05:49 PM
X2BOARD's Avatar
What CEL code are you getting ?
Which diagram did you use ?
OBD1 and OBD2 harnesses are different.
Old Apr 14, 2004 | 06:47 PM
Syner-G-Racing LLC's Avatar
Default Re: (X2BOARD)
if your running a p28 on a ob2 system you have to re pin you connectors if not your **** will throw all kinds of cells get an adapter harness from lo cash racing and see if that helps you out. you probly have the oil pressure wires and v tec crossed up because their different on the later model harnesses
Old Apr 14, 2004 | 08:04 PM
X2BOARD's Avatar
Default Re: vafc install help! (JBLSVTEC)
I think he has the harness already.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JBLSVTEC &raquo;</TD></TR><TR><TD CLASS="quote">...for a 96 civic 2000 usdm itr motor in with obd2-obd1 harness and p28 mugen chip...</TD></TR></TABLE>
Old Apr 15, 2004 | 11:57 AM
JBk24crx's Avatar
i fixed the problem this morning, i found the vtec pressure wire not getting signal from the ecu(code 22) ,so i rewire the damn thing and is ready for some action thanx for your advice.
EG-SIXV-TEC
15
Jan 19, 2011 04:43 PM
ptsaurus
May 30, 2004 08:37 AM
MAD ITR 55
Dec 7, 2003 04:23 PM
tommy b
Jul 23, 2003 07:45 AM
