aftermarket starters
Old Apr 15, 2004 | 06:02 AM
CSRacing's Avatar
Default aftermarket starters
where can I find a aftermarket starter for a Bseries engine, looking for a high torque starter no reman crap....looked every where cant find any info on any, I know someone is making them because I received a email for performance starters a few months back, but cant find it now...
Old Apr 15, 2004 | 06:43 AM
VtecDeMoN's Avatar
Default Re: aftermarket starters (CLAY SLOAN)
Just out of curious why do you need a "performance" starter. OEM should be just fine for just about any setup you could think of.
Brian
Old Apr 15, 2004 | 07:21 AM
CSRacing's Avatar
Default Re: aftermarket starters (VtecDeMoN)
this is going on my allmotor drag car, if I could find a (new) denso starter,I think that would work, but every where I find them they are reman starters, I have already went through four starters this spring on my new engine, I used denso starters last year on my race car,that had around 150,000mi on them, and they worked fine, but this year our engines are a little bigger and more compression. the main problem is the benix clutch, is slipping, but the reman starters from the parts store, are just weak, they have problems even turning over the engine. I know that if I could find a new fresh denso that it would work, but I cant even find anyone who carrys new ones..Hell a reman from honda is over $250 so I know a new denso will be even more, thats why I am asking about a aftermarket starter..
Old Apr 15, 2004 | 08:20 AM
VtecDeMoN's Avatar
Don't know if this would help you but check out autozone. They have two different starters available, non-reman'd. Both have core values but it just might be something to try.
Brian
Old Apr 15, 2004 | 08:59 AM
MightyMouseTech's Avatar
I would just get the one from the dealer. A lot of the so-called re-man starters and alternators I get from the dealer are actually brand new pieces, rebadged as reman (if you can believe it) You can actually peel off the reman sticker, and the new sticker is still on there.
Probably the main reason why you have been going through starters is because you are using cheap rebuilts. Use Honda or BOSCH. Nothing else.
Old Apr 15, 2004 | 11:09 AM
VtecDeMoN's Avatar
Default Re: aftermarket starters (MightyMouseTech)
Really? I don't understand the point in doing that. Are you sure they don't take a bad starter, reman it then place a sticker over the original?
Brian
Old Apr 15, 2004 | 11:33 AM
You have to see one. They look BRAND new, every piece, every nut/bolt/washer, NOTHING has been re-used. IF it is a rebuilt, the only thing they re-used was the part # of a starter/alternator.
Old Apr 15, 2004 | 11:35 AM
VtecDeMoN's Avatar
Damn sounds interesting. I'll have to see one in person. As a honda/acura tech, do you know the standards that honda has for their reman'd goods? IE, what little pieces must be replaced...etc
Brian
Old Apr 15, 2004 | 11:45 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecDeMoN &raquo;</TD></TR><TR><TD CLASS="quote">Damn sounds interesting. I'll have to see one in person. As a honda/acura tech, do you know the standards that honda has for their reman'd goods? IE, what little pieces must be replaced...etc
Brian</TD></TR></TABLE>
I open box, part look new, put part on car.
[geeze, I sound like a Midas/Speedy/Pep Boys/Crappy Tire technician ]
Old Apr 15, 2004 | 12:31 PM
dmotoguy's Avatar
we do lots of reman parts at our shop with no problems, ive never had problems.
Old Apr 17, 2004 | 11:08 PM
turbohondask's Avatar
Default Re: aftermarket starters (dmotoguy)
i dont think anyone makes high power startes for honda but i could be wrong,
are you sure it is slipping or is it the teeth not grabing the flywheel? I never had any problems with a reman starter
JJ-Built
29
May 5, 2006 10:26 PM
jisu009
24
Dec 14, 2005 04:01 AM
bugsy
51
Aug 5, 2004 09:24 AM
96BlackHB
May 26, 2003 12:59 PM
