v-tech
Old Apr 14, 2004 | 05:54 AM
delsol6386's Avatar
Default v-tech
what exactly does v-tech do?
Old Apr 14, 2004 | 06:04 AM
JimBlake's Avatar
Default Re: v-tech (delsol6386)
It allows you to make phone calls... Oh wait, I bet you mean VTEC... (Sorry, I couldn't resist)
It's a camshaft with different cam lobes that engage at higher rpms. Depending on which engine you're talking about, it does different things. The ones in a B18C (Integra GSR) give the engine good breathing at high rpms, but go back to more normal cam profile so it still behaves normal at lower rpms. On other engines Honda sets it up to improve emmissions or improve gas mileage, or whatever...
Old Apr 14, 2004 | 06:31 AM
crxgator's Avatar
900mhz of pure powA...
Old Apr 14, 2004 | 08:29 AM
spaceman's Avatar
Default Re: v-tech (JimBlake)
lol
Old Apr 14, 2004 | 10:26 AM
Pariah's Avatar
an added note.
sohc vtec's only change your intake cam, not your exhaust cam lobes.
Old Apr 14, 2004 | 10:30 AM
Kal's Avatar
Kal
Default Re: (Pariah)
it allows me to talk to friends and family
Old Apr 14, 2004 | 10:36 AM
what the...'s Avatar
V-tec. Say it with me...vvvvvvvv-tec.
The way vtec works relies mostly on your cam lobes. On DOHC engines like the H22, there are two sets of lobes on each shaft. The smaller lobe is the non vtec lobe, and the larger lobe is you're mac daddy vtec lobe. When the engine reaches a certain RPM rate, the ecu (basically) kicks the piston to the larger, longer vtec lobe, allowing for some extra oomph. The reason this creates more power is because the longer lobe is more efficient at higher engine rpms than the shorter one is. It's the same reason why stage 2 cams at idle sound rough, becuase they are less efficient at lower rpm ranges. V-tec was hondas answer to trying to mix both ends of the spectrum, high end power vs. low end fuel efficiency. The only bad thing about vtec is that people constantly misspell it, which inevitably ends in someone getting smacked with a valve cover.
Old Apr 14, 2004 | 03:01 PM
XLR8 GS-R's Avatar
Default Re: v-tech (crxgator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxgator &raquo;</TD></TR><TR><TD CLASS="quote">900mhz of pure powA... </TD></TR></TABLE>
HAHAHA
I actually have the vtech phone too.
VTEC= variable valve timing and lift electronic control
Basically at a select RPM the change of cam lobes equal for more HP, while retaining good fuel economy and mild torque. The way the cam variation changes Its like having two engines in one car, one GEO 3-banger for the tree huggers, and one Chevy 454 big block for the muscle heads
Old Apr 16, 2004 | 08:06 AM
mrnicolas's Avatar
my vtech gives me 2.4 gigaherts or something if talking power, it also has a digital answering machine with the call blocker!
Old Apr 16, 2004 | 08:30 AM
Sliced Beard's Avatar
Default Re: (mrnicolas)
sweet
i wish i had a phone line to connect my v-tech to
m4D cR4zy 3rD ButTOn B33p y0!
Old Apr 16, 2004 | 09:09 AM
Si Erik's Avatar
Default Re: (dirtyd463)
why can't n00bs learn how to search..damn that really pisses me off
Old Apr 16, 2004 | 09:30 AM
truent's Avatar
Default Re: (CivicSi2000)
if that really pisses you off, i think you need to rethink your life.
Old Apr 16, 2004 | 10:05 AM
mrnicolas's Avatar
I am going to go home and glue the VTECH logo off my phone box on the back of my hatch since we did my swap this week!!!!
why this?
Old Apr 16, 2004 | 10:38 AM
dfoxengr's Avatar
&lt;&lt;&lt;-------who loves these thread..
http://www.howstuffworks.com
Old Apr 16, 2004 | 03:19 PM
eg_type_r93's Avatar
Default Re: v-tech (hybridvteceg)
vtech is a phone you use it to call people
Old Apr 16, 2004 | 03:28 PM
4inspeed's Avatar
Default Re: v-tech (eg_type_r93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg_type_r93 &raquo;</TD></TR><TR><TD CLASS="quote">vtech is a phone you use it to call people </TD></TR></TABLE>
you could have been more original
Old Apr 16, 2004 | 05:19 PM
4crx4me's Avatar
Default Re: (truent)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by truent &raquo;</TD></TR><TR><TD CLASS="quote">if that really pisses you off, i think you need to rethink your life.</TD></TR></TABLE>
LOL
Old Apr 16, 2004 | 06:09 PM
98-ls's Avatar
Default Re: (4crx4me)
what color vtech doest everyone have, i got clear blue
Old Apr 16, 2004 | 06:46 PM
98-ls's Avatar
Default Re: (98-ls)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98-ls &raquo;</TD></TR><TR><TD CLASS="quote">what color vtech doest everyone have, i got clear blue</TD></TR></TABLE>
im just lieing to be cool just like my car my phone doesnt have v-tech
Old Apr 16, 2004 | 11:28 PM
zensoku207's Avatar
i just had to post to make sure someone said something haha
Old Apr 16, 2004 | 11:53 PM
92b16vx's Avatar
Default Re: (what the...)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by what the... &raquo;</TD></TR><TR><TD CLASS="quote">V-tec. Say it with me...vvvvvvvv-tec.
When trying to correct improper spelling, try not to put a hyphen in an unhyphenated ancronym.
Old Apr 17, 2004 | 03:39 AM
mycivicstoo(s)low's Avatar
Default Re: (92b16vx)
Very informative thread.
Old Apr 17, 2004 | 11:49 AM
MikeMAN's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92b16vx &raquo;</TD></TR><TR><TD CLASS="quote">
When trying to correct improper spelling, try not to put a hyphen in an unhyphenated ancronym. </TD></TR></TABLE>
everyone knows its V-T-E-C---------------------------------
Old Apr 17, 2004 | 01:46 PM
mrnicolas's Avatar
my vtech is black
Old Apr 17, 2004 | 01:52 PM
MikeMAN's Avatar
mine is the clear baby blue with pink lights inside, and its ringtone is the weekly time that the bachelor is on tv..
mike
