Maintenance on ZC engine in 91 Crx si
Can anyone give information on spark plugs, oil filters, products, brands etc. so that I can give my ride a tune up. Any extra knowledge on this motor will be helpful, thanks.
spark plugs-ngk
wires-ngk or honda*
fuel filter-honda
oil filter- honda for the s2000
oil- whatever you like, i use 5w30 castrol gtx
air filter- whatever
pcv- honda
everything is for a 88-91 crx si except the wires which need to be 86-89 integra...
wires-ngk or honda*
fuel filter-honda
pcv- honda
Thanks for the info! I have another question, When I want to add bolt on mod do I buy for the si motor or the zc. Where can find bolt ons for the ZC engine?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxgator »</TD></TR><TR><TD CLASS="quote">spark plugs-ngk
wires-ngk or honda*
fuel filter-honda
pcv- honda
everything is for a 88-91 crx si except the wires which need to be 86-89 integra...</TD></TR></TABLE>
What about the ignition rotor? That is always changed on a major tune up, along with adjusting the valves.
wires-ngk or honda*
fuel filter-honda
pcv- honda
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sonofmoejoe »</TD></TR><TR><TD CLASS="quote">Can anyone give information on spark plugs, oil filters, products, brands etc. so that I can give my ride a tune up. Any extra knowledge on this motor will be helpful, thanks.
if you want things such as a header, ignition parts, gaskets, etc. , look into buying parts for a US 88-89 integra engine.
A 88-91 SOHC header will fit on a DOHC ZC engine with some slight match porting..
</TD></TR></TABLE>if you want things such as a header, ignition parts, gaskets, etc. , look into buying parts for a US 88-89 integra engine.
efracer
Oct 3, 2004 09:22 AM
