stock lugs with rotas.
Old Apr 14, 2004 | 02:09 PM
corona's Avatar
Default stock lugs with rotas.
what are the effects of using stock lug nuts on rota slipstreams?
i'm looking to buy some....but the previous owner has them mounted with stock lug nuts. i understand that this can make them seat incorrectly.
but if they are mounted correctly, and have been seated well.....it won't damage the wheel itself, will it? should i be concerned about buying these? what would happen if they weren't mounted correctly?
fyi - i am planning on using tuners if/when i get them.
thanks,
i appreciate it,
t.fish.
Old Apr 14, 2004 | 02:37 PM
GSpeedR's Avatar
Default Re: stock lugs with rotas. (corona)
Check the Rota lug holes. Are they dished (curved on the bottom) or tapered (flat angle). Most likely they will be different, but so long as the interface is the same between the two they can work.
<u>Make sure that they fit before you drive.</u> After losing a front wheel at 55mph, I can personally say that it's not somrthing that you should take care of later.
Old Apr 14, 2004 | 04:07 PM
corona's Avatar
Default Re: stock lugs with rotas. (GSpeedR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSpeedR &raquo;</TD></TR><TR><TD CLASS="quote">Most likely they will be different, but so long as the interface is the same between the two they can work.
different from what??? and the interfaces between what? the rim and the lug, you mean?
i'm not sure what the rota lug holes are....dished or curved.
unfortunately i'm a few thousand miles away from these rims....i've asked for a picture of the lug holes though. what should i look for?
thanks.
Old Apr 14, 2004 | 04:28 PM
corona's Avatar
bump....
bottom line...
i want to know if these wheels could be damaged, or dangerous to ride on, because they were once used with stock lug nuts.
thanks.
Old Apr 14, 2004 | 07:27 PM
GSpeedR's Avatar
Lugs aren't that expensive. you can get a set cheap from any tire store.
I'm speaking about the interface between the lug and the wheel. I wouldn't worry about the wheels themselves being damaged.
Old Apr 14, 2004 | 08:31 PM
Finger Lickin' good's Avatar
Im using rota c8's. stock lug nuts, everying fine. After year, the power coat gets ground off around the lug nuts, but no cronic peeling of powercoat. Post some pics.
Old Apr 14, 2004 | 08:47 PM
corona's Avatar
Default Re: stock lugs with rotas. (...1STP KLOSER...)
got some pictures....the lug holes look fine.
thanks for the help guys. i appreciate it.
and i'll be sure to get some tuner lugs before i mount them.
EvenStar
Dec 12, 2006 12:40 PM
teg racer 877
Feb 5, 2006 04:23 PM
Slammed Ek9
41
Jul 10, 2005 11:00 AM
dukers
Jul 1, 2004 01:16 PM
EleanoR
Jul 10, 2002 04:32 AM
