fuel injectors (remove/install) G3
Old Apr 15, 2004 | 12:10 PM
nyo91's Avatar
Default fuel injectors (remove/install) G3
I have a 95LS and I am thinking of cleaning out my fuel injectors. Question is, are these simple to remove and reinstall?
I did a search, but could not come up with a remove/install process.
any help would be
Thanks!
*EDIT*
I am told that I would prolly need to change the O-RINGS while I am istalling the injectors, I found out that there is a top and bottom O-RING, I am providing a diagram below, if someone could tell me which O-RING I would need.
THANKS!
*EDIT*
Modified by nyo91 at 4:33 PM 4/16/2004
Modified by nyo91 at 4:48 PM 4/16/2004
Old Apr 15, 2004 | 12:28 PM
Sack Master's Avatar
Default Re: fuel injectors (remove/install) G3 (nyo91)
10mm socket is all you really need. 2 bolts holding the injector harness on and 3 holding the fuel rail on. You will need to relieve the fuel pressure also. There is a relief on top of the fuel filter, or you could just do what I do and take the fuel line off the rail. I think its a 22mm wrench you'll need. After that the injectors just pop out of the intake manifold and off the fuel rail. It takes about 5 minutes total to take them off. Replacing them is just as easy. I would however recommend getting new o-rings for them. They have been known to leak after you do that. But most of the time you are fine.
Old Apr 15, 2004 | 02:06 PM
dfoxengr's Avatar
Default Re: fuel injectors (Sack Master)
takes me like 7 mins to take out all 4injectors
Old Apr 15, 2004 | 02:29 PM
nyo91's Avatar
hey thanks!
I will give it a try this weekend.
Old Apr 16, 2004 | 10:18 AM
luckster's Avatar
Default Re: fuel injectors (hybridvteceg)
do you know if i need an resistor box with 440 dsm injectors, i figure not cause they should be saturated injectors correct?
Old Apr 16, 2004 | 10:20 AM
dfoxengr's Avatar
Default Re: fuel injectors (luckster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by luckster &raquo;</TD></TR><TR><TD CLASS="quote">do you know if i need an resistor box with 440 dsm injectors, i figure not cause they should be saturated injectors correct?</TD></TR></TABLE>
depends on what OBD your car is. search there are 1000 thread on this subject alone.
Old Apr 16, 2004 | 12:37 PM
nyo91's Avatar
*edited*
Old Apr 16, 2004 | 12:38 PM
dfoxengr's Avatar
no you dont have to.
96ek
13
Sep 2, 2013 10:35 PM
csckwade
Jan 7, 2013 09:00 AM
Ross45323
Honda Civic (2001 - 2005)
May 6, 2008 03:08 PM
nyo91
Apr 16, 2004 02:44 PM
satan_srv
Dec 11, 2003 08:59 PM
