Oil light ...help
Old Apr 15, 2004 | 05:24 AM
92CIVICCX's Avatar
Default Oil light ...help
so i just recently did a new headgasket on my 93 dx... everything seemed to be running fine for like 2 weeks now until this morning my oil light started blinking off and on.... then as i started getting home to check the problem it started making a rattling noise from driver side cylinder... oil level is fine.. i removed the spark plug from that cylinder and it had a white chalky residue on the top..
Old Apr 15, 2004 | 05:43 AM
92CIVICCX's Avatar
Default Re: Oil light ...help (92CIVICCX)
anyone got any ideas..
Old Apr 15, 2004 | 07:13 AM
Autotoolman's Avatar
You can get tools that will get the code for the oil light as well as other diagnostics for your car on eBay
http://cgi.ebay.com/ebaymotors...27462
Old Apr 15, 2004 | 07:41 AM
mmuller's Avatar
Mad Scientist
Default Re: Oil light ...help (Autotoolman)
you should test your oil pressure, the oil light comes on when the car has under 5psi
Old Apr 15, 2004 | 10:06 AM
92CIVICCX's Avatar
Default Re: Oil light ...help (mmuller)
checked oil dipstick.... there isnt even any oil level on it let alone any oil on it.... so i think im gonna drop the oil pan change oil filter and see if there is any thing in the oil ..... i think something is clogged but i have no clue where
Old Apr 15, 2004 | 11:44 AM
onePOINTsix's Avatar
you didnt change the oil when you did the swap
Rule 1: Change ALL fluids when you do a motor swap, this includes oil, tranny fluid and coolant
edit: opps i read it wrong, you might havea leak, but a clog is more then likely
Old Apr 15, 2004 | 04:13 PM
92CIVICCX's Avatar
Default Re: Oil light ...help (Sideout)
its allways some stupid small thing that screws everything up... after looking around for a while draining what 1 quart of oil i had and uncloging everything i noticed my oil pan had some residue on it... so i siad ill take a look at my oil pan bolt .. ho th *** it was leaking form it i do not know but i rplaced the bolt and washer and oil level has stayed fine now.... and hopefully will
Old Apr 15, 2004 | 05:45 PM
LSVTEC 91 Civic's Avatar
Banned
Get a mechanical oil pressure gauge, so you know exactly how much psi you have.
Old Apr 15, 2004 | 06:38 PM
SleepyHF's Avatar
while the car is running at idle, pull the oil sending unit plug. The oil light should come on right away. If it doesn't you have a bad sending unit. But NO oil on the dipstick. damn that suck. Like you said drop the pan. But the dipstick goes right down into the pan, so i dont see why no oil. Drain the oil and see how much oil is in the pan. Should be 3.8 qts. They way you are explaining, is simple...YOU HAVE NO OIL!!!
Old Apr 15, 2004 | 07:12 PM
mmuller's Avatar
Mad Scientist
Default Re: Oil light ...help (SleepyHF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SleepyHF &raquo;</TD></TR><TR><TD CLASS="quote">while the car is running at idle, pull the oil sending unit plug. The oil light should come on right away. If it doesn't you have a bad sending unit. But NO oil on the dipstick. damn that suck. Like you said drop the pan. But the dipstick goes right down into the pan, so i dont see why no oil. Drain the oil and see how much oil is in the pan. Should be 3.8 qts. They way you are explaining, is simple...YOU HAVE NO OIL!!!</TD></TR></TABLE>
actually, if you pull the plug of the stock oil pressure switch, the oil light will not come on.
Old Apr 16, 2004 | 08:46 PM
SleepyHF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">actually, if you pull the plug of the stock oil pressure switch, the oil light will not come on.</TD></TR></TABLE>
Really?? Thanks for the correction. Mine was doing the same thing. I called Honda, and the tech there said "If you pull the oil sending unit plug out while the car is running, it should throw a light". I said "why". He said. "Because when you pull it out, the plug does not see ANY oil pressure". I said. ok cool
Old Apr 16, 2004 | 10:57 PM
mmuller's Avatar
Mad Scientist
Really?? Thanks for the correction. Mine was doing the same thing. I called Honda, and the tech there said "If you pull the oil sending unit plug out while the car is running, it should throw a light". I said "why". He said. "Because when you pull it out, the plug does not see ANY oil pressure". I said. ok cool </TD></TR></TABLE>
well, i have mine disconnected.
the stock switch is grounded through the block, if you disconnect the connector the light wont come on; unless of course it touches ground
Old Apr 20, 2004 | 08:51 AM
92CIVICCX's Avatar
just the other night now my dam light started st flicker agian and bog down when trying to accelerate..wtf and there is oil pumping through but the pinging is slowly coming back
Old Apr 24, 2004 | 01:10 PM
MoogieBoogie's Avatar
I don't have the same problem with the oil, but I also did find white chalky residue at the top of the spark plug. My engine doesn't start and my guess is that a warped head from a blown headgasket. Anyone have any ideas what the white chalky residue is?
Thanks,
-Brian.
itzyaboyzeem03
Jul 1, 2016 04:40 PM
ludeman92
Nov 10, 2005 11:02 AM
Mr. Samurai
10
Feb 28, 2005 05:59 PM
1hotintegra
Dec 15, 2002 08:00 PM
Allstar
Oct 29, 2001 03:05 PM
