Bleeding A Hydro Clutch
Old Apr 16, 2004 | 10:40 PM
d16y8turbo's Avatar
Default Bleeding A Hydro Clutch
hey, a friend of mine and me blead the clutch fluid tonight, but now the clutch has no resistance. when i push it down it stays down to the floor, and when i put my foot under it to lift it back up it springs back up. any ideas on what's wrong or what we did wrong while bleeding the system? thanks!!
Old Apr 16, 2004 | 10:56 PM
zensoku207's Avatar
The best way to bleed the clutch, IMO, is pump the pedal hard 3 times to the floor, holding on the 3rd. Then have the 2nd person open the bleeder valve on the tranny, stopping when all the air is out of the line, then repeating until its only fluid, and no bubbles.
If this doesn't work, there may be a leak in the line. hth
Old Apr 17, 2004 | 05:48 PM
doublejz's Avatar
Default Re: (zensoku207)
just go to advanced and buy the cheapo oner person hydro line bleeder. Its just a small bottle with fittings that will go into your bleeder. top off your reservoir and pump and pump and pump. Keep checking the lines for air bubbles. Repeat until no bubbles are visible.
-this is great if your just doing it yourself. if you have a helper do how zensoku207 said
Old Apr 17, 2004 | 10:40 PM
d16y8turbo's Avatar
thanks for the help!! got it!
ja20_eg
Sep 17, 2012 03:54 PM
cashkeith
Mar 31, 2008 01:37 PM
jdmh22luda
Jul 26, 2007 01:02 AM
Bserieskiller
Feb 17, 2006 05:52 PM
toooslow
Jun 12, 2003 09:49 AM
